Possible Clutch issue or my imagination?
Old Jan 16, 2010 | 03:16 PM
wilson7136's Avatar
wilson7136
Default Possible Clutch issue or my imagination?
I have noticed the last coupe of trips down the interstate that if I am in 6th gear running about 80 (2800 rpms..) I give it the gas to pass and I get a brief blip in the rpms and then it quickly returns to normal. Reminds me of a slipping clutch. Oddly I can not get it to slip any other time or way. Different gears, fast takes off's or crappy shifts. 82,000 trouble free miles on a 2005. Maybe the solution is to not pass in 6th......or hope I was dreaming. Anyone else had this happen to them or is it a sign of things to come.
Thanks.
Old Jan 16, 2010 | 06:07 PM
What are you passing at 80 MPH? An air plane?
Old Jan 17, 2010 | 06:17 AM
wilson7136's Avatar
wilson7136
I see your from Baltimore, must have never seen 80 on an interstate.
Old Jan 17, 2010 | 10:30 AM
LuciaPwNs's Avatar
LuciaPwNs
Best way to tell if its you or the car is just floor it in a higher gear. if it slips, its time to change your clutch. But it should do the same thing whether it is in 4th 5th and 6th.
Old Jan 17, 2010 | 10:38 AM
kacz07's Avatar
kacz07
Do you have a pop charger? Sounds like the stalling issue at 80mph in 6th gear.
Old Jan 17, 2010 | 11:57 AM
wilson7136's Avatar
wilson7136
I do have a pop charger but have not heard of this issue. Can you explain futher or point me to where I can investigate?
Thanks for the response. I fail to see the humor in people who reply that are clueless. I think some people repond the way they do to give them something to do with their sad life.
Old Jan 17, 2010 | 05:56 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Are you talking about a tiny bounce of the tach? If so, that is normal. If it's slipping a few hundred RPM and then grabbing again your clutch is on the way out. 6th puts a lot of load on the engine, so you might get slip in higher gears, but not the lower gears. Hope that helps.
Old Jan 17, 2010 | 08:30 PM
dirtbikr's Avatar
dirtbikr
6th will be the first gear that you notice slipping, but you may still have 10,000 or more miles if you want to milk it. Just downshift to 5th and pass that way, save some clutch surface and make it easier on the motor.
Old Jan 18, 2010 | 03:32 PM
wilson7136's Avatar
wilson7136
Thanks for all the great answers. It is a small blip, probably 3-400 rpm's. I will also look into the pop charger issue. I do believe my fan switch was on and I have removed the heat shield.
Old Jan 19, 2010 | 08:11 AM
musubi's Avatar
musubi
If you want to be sure, you can always post a video of it and we can see from there.
Old Jan 19, 2010 | 08:35 AM
vthao's Avatar
vthao
Hmm....3-400 RPMS is kinda a big blip. Post a vid, we can surely help you out.
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
