Sad Sad Dyno Sheet... :(
#42
on
Originally posted by KONVERTER
Did you Dyno in 4th gear?
because 4th gear max's out at the MPH listed in your dyno sheet...
should be dyno'ing in 5th...
Any thoughts on the plastic thingy that came with my Injen?
How about this being to much of a "free flow" system? Anybody with the exact same setup as me?
I'm worried I could be running too lean. Here is some more info from my last dyno run.
Does this look too lean? My initial baseline dyno showed the A/F ratio a consistent .8 lower throughout the rev band (ie.12.8@6200RPM's) Shouldnt it show a consisten 12.5 A/F across the board?
How far off until this will effect performance or risk of damage to the engine?
Thanks for any input
-Richard
#44
on
I am really curious to see a DYno run in 5th gear for you. baseline done in 5th or not... I bet it jumps up
Dyno run #3 and #4 done in 5th gear - 248HP
Dyno run # 6 done in 4th -251HP
bcoffee20
11-19-2015 06:39 PM
350Z Project X
Suspension
10-10-2015 09:23 AM
