Bank 1 engine camshaft sensor location picture request
Old Feb 10, 2010 | 09:18 PM
THe Emperor's Avatar
THe Emperor
Default Bank 1 engine camshaft sensor location picture request
Can someone post a picture of where the bank 1 camshaft sensor is located? I only found one picture by searching but couldn't get a good idea as to where it's located.
Old Feb 11, 2010 | 03:18 AM
terrasmak's Avatar
backside of the head on the drivers side. Its the only sensor with a wire connected to it. You access it from reaching in behind the pass side head , across the back of the motor, and remove the single 10mm bolt holding it in. Took me 5 minutes to change mine 2 weeks ago.
Old Feb 11, 2010 | 05:03 PM
QuadCam's Avatar
QuadCam
actually, bank 1 is the passenger side of the motor according to Nissan. Bank 1 has cylinders 1,3,5 (pass side).
Old Feb 11, 2010 | 05:24 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
i believe you are incorrect.
see pic from FSM
Attached Thumbnails Bank 1 engine camshaft sensor location picture request-camshaft.jpg
Old Feb 11, 2010 | 08:53 PM
THe Emperor
Thanks, but due to me being a moron I see where it says Camshaft Position sensor phase 1 but I don't see a line attached to it showing where it is....unless I'm missing something.
Old Feb 11, 2010 | 09:37 PM
winchman's Avatar
winchman
The line starts just above the upper right end of the C in Camshaft. It points in the 11 o'clock direction, and ends in a round dot. It kinda gets lost in the drawing.
"Its the only sensor with a wire connected to it."
Yeah, you gotta look out for all those sensors with no wires Nissan puts on their engines.
Old Feb 11, 2010 | 10:05 PM
THe Emperor
Thanks man! I totally missed that line.
Old Apr 13, 2011 | 10:51 AM
jgruberman's Avatar
jgruberman
Not to bring a dead thread back to life... but this is what helped me locate them to begin with... but I'm wondering which si considered the "front" and which is considered the "back" sensor. Buying a new one at autozone.com and thats how they clarify them.
Old Apr 13, 2011 | 11:15 PM
winchman's Avatar
winchman
Both of them are on the back of the engine (near the flywheel) in the Z. They're identified as bank 1 and bank 2.
It sounds like the Autozone parts system names them by where they're located when the V6 engine is mounted in a front-wheel-drive car. From the pictures I could fine, it looks like the flywheel end of the engine is to the left side of the car, so bank 1 is to the rear, and bank 2 is to the front in a fwd layout.
It looks like the sensors are different because of the way they mount on the engine. You can see it here:
http://www.courtesyparts.com/350z-pa...5_743_745.html
liqalu04
Jan 2, 2022 12:58 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Mattg350z
Oct 2, 2015 06:51 AM
nanotech
Oct 2, 2015 05:02 AM
