Chattering NOise!!
Old Feb 21, 2010 | 02:49 PM
metah24's Avatar
metah24
Default Chattering NOise!!
When i drive my car for a little while and I stop there is a chattering noise coming from the transmission. When i press in the clutch the noise goes away. When i release the clutch the noise cames back. I took it to the dealership and of courseeee they say they said they couldn't hear anything. It doesn't do it all the time but it's a 08 touring 6mt with 10k miles and its embarrasing to hear it. Any ideas??
Old Feb 21, 2010 | 02:52 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
it's the throw out bearing...a common occurance on these cars from new
Old Feb 21, 2010 | 03:08 PM
F34RL355's Avatar
F34RL355
the noise is normal
Old Feb 21, 2010 | 03:14 PM
hellsoldiers08's Avatar
hellsoldiers08
its normal. I dont like it either some times but hey if that one small imperfection and everything else is perfect, then it something you can over look!
Old Feb 21, 2010 | 03:26 PM
jtel's Avatar
jtel
I have the same exact issue with only 10000 miles. I took it to the dealership and they told me that they will replace my transmission under warranty.
Old Feb 21, 2010 | 03:57 PM
BlueZ33's Avatar
BlueZ33
my car is an 08 as well and it does the same thing. i only have 6k miles on my car.
however my 03 did the same thing
Old Feb 21, 2010 | 05:02 PM
TheFarmer's Avatar
TheFarmer
It's normal
Old Feb 21, 2010 | 05:12 PM
ITOzann's Avatar
ITOzann
turn the volume up of your cd player noise is normal
Old Feb 21, 2010 | 05:58 PM
zerostyle's Avatar
zerostyle
was it chattering like this?
Old Feb 21, 2010 | 08:12 PM
NttnbutaZthang's Avatar
NttnbutaZthang
dont be scared...anyone that knows anything about your car will know that nissan wanted it to sound that way....
Old Feb 21, 2010 | 08:13 PM
TheFarmer's Avatar
TheFarmer
As stated in the other thread, it's normal
Old Feb 22, 2010 | 06:27 AM
sir captian's Avatar
sir captian
Your axle will be making noise next,thats normal also.
Old Feb 23, 2010 | 08:40 AM
danegilli's Avatar
danegilli
Default chatter
would getting a new clutch stop this chatter? Some clutches claim to be a reduction in noise chatter, anyone noticed a diff?
Old Feb 23, 2010 | 02:25 PM
Zomgfast123's Avatar
Zomgfast123
yep same as me normal bro
Old Feb 23, 2010 | 04:08 PM
musubi's Avatar
musubi
Probably not. The dual mass flywheel is already doing a lot in quieting the chatter. I can't see it being any different with a new clutch. If you replace the flywheel with a solid lightened one, the chatter's worse.
OP, yes, it's normal.
Old Feb 23, 2010 | 04:12 PM
Jay'Z's Avatar
Jay'Z
Normal
Old Feb 24, 2010 | 03:10 PM
metah24's Avatar
metah24
you guys keep saying its normal but it isn't. The car has a slight noise and when you hit the clutch it goes away, ya thats the normal one. but this noise only happens sometimes and is loud and it sounds like someone threw quarters in the transmission and when you press the clutch it goes away so idk about normal
Old Feb 24, 2010 | 03:11 PM
DB350's Avatar
DB350
You're right. What do we know about these cars?
Old Mar 24, 2010 | 08:11 PM
TRI-AMP's Avatar
TRI-AMP
Default same here
I have the same problem on my 2007 roadster and Nissan said it is normal with these cars.
Old Mar 24, 2010 | 08:20 PM
johnwigs's Avatar
johnwigs
stop putting quarters in your transmission... it takes gold boullion or in case if emergency you can put blood diamonds to make it home.
