Best Mods to make car faster?
Old Feb 22, 2010 | 08:43 PM
  #41
puertorican's Avatar
puertorican
A better driver is needed!
Old Feb 22, 2010 | 09:48 PM
  #42
terrasmak's Avatar
Originally Posted by Sportsfan811
Tanabe Medallion Touring Exhaust. What y-pipes and test pipes should I get for it?
Stillen Intake + Air Duct. I read on here that the JWT Pop stalls at high speeds and something about it sucking in hot air, so i'll just get stillen if that is true.
Plenum Spacers(motordyne 5/16”)
Tanabe sucks if yoru trying to make power. It sounds great, i had one with the Tanabe Y pipe. Then i swapped to Motordyne and gained 9 hp , look at the motordine site. Mine is the first dyno under the shockwave.
The stillen is good as any intake, but for a lot less you can get the JWT. The Jwt sucks hot air till the car starts moving, then the hot air clears and you pull roughly 10 degree hotter air than a stock intake, but you have a lot better flow.
Old Feb 22, 2010 | 10:03 PM
  #43
INTIMAZY's Avatar
INTIMAZY
Stillen sucks hot air in as well. I was suspicious that it would since the bottom is entirely open, but it was confirmed on a dyno at MRC a while ago. However, this does not occur while moving as far as I know.
+1 on Popcharger. Cheaper and isn't much worse than anything more expensive
Old Feb 22, 2010 | 10:29 PM
  #44
RMichael's Avatar
RMichael
How much does a port and polish cost I might do that? So far I think im going to get:
Tanabe Medallion Touring Exhaust, tanabe y-pipe, helix test pipes
Stillen Intake (maybe get air duct)
Plenum Spacers(Crawford)(motordyne 5/16”)
Spark Plugs(any good brands in particular?)
Cams(any good brands in particular?)
Headers(Should I)
ECU Reflash at the end.
You did some research. Cool. But you are starting in a hole. Not only will those bolt ons not add much HP but you have the rev up motor so make sure you don't have any oil leaks because that motor is notorious for oil consumption.
GL
Old Feb 22, 2010 | 10:58 PM
  #45
GHOST1207's Avatar
GHOST1207
Originally Posted by KingBaby
I did the sand in the intake box mod....
everything works fine...don't have any dyno's but I feel a difference...
Originally Posted by Sylvan Lake V35
It gets sucked through the intake and is like an extrude hone on the intake and heads
I'm telling you sportsfan, it might sound crazy, but it works. There are very few members who had the guts to do it. Try it and get back at us on your results.
Old Feb 23, 2010 | 01:53 AM
  #46
adamciya350's Avatar
adamciya350
Ankle weights=+17 whp
Old Feb 23, 2010 | 02:05 AM
  #47
BulletMagnet's Avatar
BulletMagnet
I seriously warn you against getting a Y-Pipe, because the 350Z needs a Z-Pipe, clue is in the model name...
Old Feb 23, 2010 | 06:08 AM
  #48
MikeF350zed's Avatar
MikeF350zed
Personally, I would suggest the Thrust upgrade. I went with the SSC version. It's not cheap, but there are no superchargers or turbochargers involved. You'll need to do some minor bodywork on it and the engine needs a few minor changes. Biggest problems are the fuel it uses is expensive and it's not strictly road legal. The weight goes up, but the power improvements are worth it. It'll definitely be faster than the stock car. Video of me giving it a run in Nevada:
http://www.youtube.com/watch?v=aYxN6koH9v8
Old Feb 23, 2010 | 07:37 AM
  #49
Blck350z's Avatar
Blck350z
Starting from intake to exhaust....
-K&N drop in filter (dont' waste your money with a CAI or pop charger...) $57.00
-MREV2 (lower plenum replacement) $420.00
-5/16" Iso Thermal plenum spacer $250.00
-Stillen equal length headers (ceramic coated) $625.00
-AAM Test pipes (always had good luck with there products) $249.00
-Greddy TI-C dual exhaust $1,000.00
-UpRev software/tune (You will not feel much until you get a tune!!!!!!) $700.00...
The above is a list of quality products (not the cheapest and not the most expensive).
All of the above can be installed with simple hand tools and a bit of common garage sense... aside from tuning....
You can also do:
-JWT clutch and flywheel $775.00
-4.08 Ring and Pinion swap $470.00 (check with Andy at Performance Nissan for install kit
-LSD $500-2000
-JWT S7 cams $1,100.00
Above are more extreme N/A mods... that most people can not do in there garage at home. The labor for the above will add to the cost quite quickly ( you can count on doubling the price including install ex: $1,100.00 cams ... $1,100.00 install if your lucky)
Also if you want to get more technical ... you can start to get into suspension/lightweight tire and wheel setups. This along with a good LSD will help you hook up and get moving (bring 60' times down) and give you more control.
But by this point you could do a vortech (sc-trim) or single turbo(boosted performances' when he gets all the bugs worked out or a Power Lab kit) for less then what I have listed above.
Old Feb 23, 2010 | 11:41 AM
  #50
Erdem's Avatar
Erdem
Built engine and TT (Twin Turbo)...
that's the way to go IMO...
Old Feb 23, 2010 | 01:17 PM
  #51
03threefiftyz's Avatar
03threefiftyz
How is this not locked yet......
Old Feb 23, 2010 | 05:48 PM
  #52
Sportsfan811's Avatar
Sportsfan811
Ok thanks
Old Feb 24, 2010 | 10:35 AM
  #53
GHOST1207's Avatar
GHOST1207
Keep us updated
Old Feb 24, 2010 | 10:45 AM
  #54
Alberto's Avatar
Alberto
Cranky FI Owner
LOL @ the "experts" recommending headers!
I have yet to see a car with headers outperform my old NA setup in both power and TORQUE numbers or on the strip.
Old Feb 24, 2010 | 11:16 AM
  #55
03threefiftyz
+1.....stock manifolds here too.
Old Feb 24, 2010 | 08:19 PM
  #56
IbarraZ33's Avatar
IbarraZ33
i like peepee's
F4G.
Old Feb 26, 2010 | 12:08 AM
  #57
kramykram's Avatar
kramykram
ibtl
Old Feb 26, 2010 | 12:15 AM
  #58
terrasmak's Avatar
Headers here, but drag racing is boring.
Old Feb 26, 2010 | 04:46 AM
  #59
Synjn's Avatar
Synjn
Originally Posted by GHOST1207
The usual port and polish is a couple grand. That's why I went with my own route, and those mods would go perfect with the sand port polish. If you are scared it might harm your aftermarket parts, just do on the stock intake/headers/exhaust. A tune from dyno revmaster would finish if off nicely.
ROFL
Old Feb 26, 2010 | 05:17 AM
  #60
rajinj's Avatar
rajinj
since your an 06 you should get the DE lower plenum and replace it with what you got.. then i heard with the 06 if you get like utec and advance timing by 3 degrees it hauls ***.. pulls on HRs too
