Sound Performance Differential Brace kit!!
Old Mar 2, 2010 | 07:19 PM
Reid@SP's Avatar
Reid@SP
All hardware is included. We do not have a write up for it, but that would make for a nice DIY.
Reid
Old Mar 3, 2010 | 04:43 PM
Reid@SP's Avatar
Reid@SP
I have 4 kits being made right now!
Old Mar 3, 2010 | 04:49 PM
Jay'Z's Avatar
Jay'Z
Price dropped?
Old Mar 3, 2010 | 04:57 PM
Reid@SP's Avatar
Reid@SP
$199 is cheap insurance for your differential case!
Old Mar 3, 2010 | 05:02 PM
Jay'Z's Avatar
Jay'Z
Pretty pricey for that little piece IMO.. GL with sales though.
Old Mar 3, 2010 | 05:11 PM
Reid@SP's Avatar
Reid@SP
I usually wouldn't take the time to pull this apart, but it really is not a pricey piece. Taking into consideration our overhead, materials, direct labor, and the hardware included, it's pretty reasonable. Injected's brace uses one bar instead of our twin setup and we only charge $50 more.
Reid
Old Mar 3, 2010 | 07:24 PM
rcdash's Avatar
rcdash
I think the price is just fine. I'm just not prepared to grind my nismo cover. If you could design it so it goes around the fins, it would work for either and the market would be a tad bigger! So how do you know exactly where to drill the holes from the back of the rear subframe? Got a template or something?
Old Mar 3, 2010 | 07:44 PM
Reid@SP's Avatar
Reid@SP
I understand not wanting to grind your diff cover, but it may need to happen for you sooner or later with your setup!
You can see in the pictures where the 2 holes need to be drilled. Now that we are selling more of these, I will try to see if I can get some kind of template or instructions made for the ones we aren't installing.
Reid
Old Mar 3, 2010 | 08:10 PM
rcdash's Avatar
rcdash
I'm trying to figure out a way to tempt you to redesign to clear the fins so I don't have to do any grinding! Is there a way (besides a wad of $$$)?
And a template would be great - don't want to just wing it and have the hole be slightly off! I think getting a drill on the front side (diff side) of the rear subframe would be tough. Is that what you do? Then you could just mount on diff, mark, and drill.
I have the DSS level 5 pro axles, so I think my "weak link" is either the 5AT or that rear diff bolt, but I'm not exactly sure... I am tuning for more power, but I'm trying to keep torque around or below 500 throughout the powerband for the sake of the trans. Not sure if I can break that mounting point with "only" 500-550 wtq. Also I think the fluid coupling of the TC helps absorb the shock, but I may just be reassuring myself falsely!
Old Mar 4, 2010 | 06:50 PM
Reid@SP's Avatar
Reid@SP
Unfortunately I don't forsee a redesign any time soon. We have lots on our plate right now and would need a car in here with a Nimso diff cover to do it. As for the template, I spoke with our fabricator today. He knows it needs to be done but like I said, we have a lot going on and need to find the time to make it.
As for your mods and power level, you can honestly snap the diff case at any power level if you launch it hard enough. I want to say your single bolt on the diff case is your weak link for sure. Your TC may be helping a tad bit, but the drivetrain is still taking that first shock really hard when you first launch the car, not to mention any wheel hop you have.
Reid
Old Mar 8, 2010 | 09:46 AM
The Fallen's Avatar
The Fallen
Bump for pics.
Old Mar 8, 2010 | 11:46 AM
Reid@SP's Avatar
Reid@SP
Install pics!!!!!
Drive shaft and axles unbolted from diff
Drilling first hole
First hole done
Drilling hole #2 (Check out Vince's face!!)
2nd hole finished
Both holes
Diff Brace in place with hardware
Final picture (still needs torqued)
Another angle
Reid
Old Mar 8, 2010 | 04:25 PM
BrazenZ's Avatar
BrazenZ
It would be better if you make the passenger side brace so that it could ultitlize the existing hole just like Injected Peformance brace, but still bolting on the front side of the subframe. As long as I can keep my GTspec rear brace I'm happy.
Old Mar 8, 2010 | 08:52 PM
Reid@SP's Avatar
Reid@SP
That would require the brace to have two different designs for each side. We figure if guys are willing go drill one hole, then a second wouldn't be a big deal.
Reid
Old Mar 11, 2010 | 03:39 PM
Reid@SP's Avatar
Reid@SP
No one cares?!?!?!!?
Old Mar 11, 2010 | 06:46 PM
350Z400rwhp's Avatar
350Z400rwhp
Do you have to remove the driveshaft and axles to install this?
Old Mar 11, 2010 | 06:50 PM
350Z400rwhp
Oh and the diff too?
Old Mar 12, 2010 | 02:39 AM
  #38
weak 350z's Avatar
weak 350z
Do you have a picture of just the brace uninstalled? I want to see if the brace has sleeves that go through the sub frame or is it just bolts?
Old Mar 12, 2010 | 11:23 AM
  #39
Reid@SP's Avatar
Reid@SP
350Z400rwhp- Yes the diff must be unbolted from the axles and driveshaft and dropped to install.
weak 350z- I wish I snapped a few pics! I just shipped out a kit today. It does come with the sleeves along with the rest of the necessary hardware.
Reid
Old Mar 18, 2010 | 02:48 PM
  #40
The Fallen's Avatar
The Fallen
What size drill bits did you use?
