Had a boo-boo
Old Feb 24, 2010 | 10:43 PM
John Bronze's Avatar
John Bronze
Default Had a boo-boo
Ok, so I made the mistake of trying to jack up my car from the cross member, and had the jack slip to where it fell on the oil pan. So I removed the oil pan to make sure I didn't **** up the oil pickup, so after inspecting it, the oil pickup seems fine, but the metal around the screen got bent up pretty bad. I was thinking of taking some tin snips and cut the metal part off to expose the screen some more. My question is has anybody done this? I really don't see any cons in doing this, but I just want to double check here to see if anybody has done it before. Any input is appreciated. Thanks.
Here's a pic of the metal part I am talking about.
Old Feb 25, 2010 | 01:21 AM
duro78's Avatar
duro78
Damn that sucks
Old Feb 25, 2010 | 03:30 AM
3-fifty-WeEe's Avatar
3-fifty-WeEe
tin snip away, thats just the filter over the pump. no biggie
Old Feb 25, 2010 | 03:55 AM
ThreeFiveZero Z's Avatar
ThreeFiveZero Z
Could be worse...be more careful!
Old Feb 25, 2010 | 10:35 AM
honeybadger's Avatar
honeybadger
keep a careful eye on the oil pan if youre not gonna replace it, over the next couple of months.
Old Feb 25, 2010 | 10:37 AM
VO...'s Avatar
VO...
Administrator
Ouch!
VO(wondering where all the jackstands were at when this happened)
Old Feb 25, 2010 | 10:52 AM
huyrua's Avatar
huyrua
Good way to save weight.
Fortunate that you waren't under the car when it happen
Old Feb 25, 2010 | 11:55 AM
Zazz93's Avatar
Zazz93
I'd swap it out. If I remember, its only five more bolts before it comes out so its not time consuming. The reason I say swap it is, it hard to tell if it is at the exact level it should be at. If it was bent in the upper area and lost a half inch of distance in to the pan you could run low and damage something before the sensor catches a problem. And its only $20.
http://www.trademotion.com/partlocat...layCatalogid=0
Old Feb 25, 2010 | 12:05 PM
JasonZ-YA's Avatar
JasonZ-YA
That!
Whos to know if that pick up shield is meant to have the opening "sized" it has for pressure on pick up....
Example - laymens terms:
if a vacumme cleaner has a narrow end for picking up junk in the corners of base boards the suction pressure is different than if it has the wide mount opening attachment......ie, cutting the tin bigger...
Does anyone know if that section retains the mess screen in place??? if something pops out ladder you will have FOD (foreign object that will cause damage).
-J
Old Feb 25, 2010 | 12:18 PM
Zazz93's Avatar
Zazz93
This is the most important reason for replacing it... I can just see the forum post now...
Can you believe a $20 part caused $6,000 in repairs!
Old Feb 25, 2010 | 12:22 PM
themadhatterxxx's Avatar
themadhatterxxx
That's probably a sign to get these:
http://www.acehardwaresuperstore.com...80.html?ref=42
Old Feb 25, 2010 | 12:36 PM
John Bronze
Ya, I got some nice bruises on my hand hammering that pan out, so it better be fine! lol
Originally Posted by vo7848
Ouch!
Happened while I was jacking up the car.
Good point! I guess I'll pick up a new one for cheap insurance.
That!
-J
I see where you're getting at. Thanks a lot for the input fellas.
I have those. lol I just didn't want to jump the car, cuz the battery is dead, so I thought I'd be all ninja like and try to jack the car up from the middle and put it on stands real quick. lol
