K@N filter for the 350Z
Old Oct 29, 2003 | 11:38 AM
gmoney's Avatar
gmoney
Default K@N filter for the 350Z
I was wondering if anyone has put a K@N filter on their car and what kind of HP and torque boost it gave you.
I have heard that it gives 3 or 4 HP but never got any thing for sure.
Old Oct 29, 2003 | 11:44 AM
Zsilverstone13's Avatar
Zsilverstone13
I don't have K&N filter in my Z, but I am very sure that you won't feel any different than the stock filter.
Old Oct 29, 2003 | 11:46 AM
Jen@WestCovinaNissan's Avatar
Vendor - Former Vendor
Default Re: K@N filter for the 350Z
The K&N Drop in for the 350z increase's HP in the upper rpm range. Another advantage is the K&N can be re-used up to 1,000,000 miles with their filter cleaning kit's.
OUR cost of the K&N filter is $39.95
Our cleaning kit is $8.95 and lasts for a few cleans. You will save money over time with this.
The filter is on our web site www.performancenissanparts.com and we will be adding the cleaning kit shortly.
Old Oct 29, 2003 | 12:13 PM
zand02max's Avatar
zand02max
I paid $44.95 for mine, didn't notice any increase in HP, however, its good for 1 million miles, and you never have to discard it, just use the recharge kit.
I heard of some folks having problems with too much oil on the filter and the check engine light going off.
I haven't had a problem with mine.
Old Oct 29, 2003 | 01:00 PM
AndyB's Avatar
AndyB
Default K&N
Most reports I have seen say that there is not much (if any) power gain with the K&N filter install on a Z. The stock system is pretty good.
You _might_ see report of 1-2 HP, but that is well within the error margin of a dyno. Even full cold air kits aren't showing serious gains for the most part.
The check engine light problem is probably the oil on the air flow sensor problem. Oiled filters can deposit oil on the air flow sensor leading to a malfunction, a check engine light, and the costly replacement of the sensor.
Since it is hard to know _exactly_ how much oil to apply and since even the pro-filter people only claim 1-2 hp, I decided it was not worth the hassle and the risk.
Cleaning and re-oiling the filter can be a bit of messy chore, I have a K&N on my Durango where the alternate cold air intake kit actually makes a significant difference due to the poor stock airbox design.
Paper filters are cheap, easy to replace, and can't hurt the sensor.
that's just my opinion of course....
Old Oct 29, 2003 | 01:02 PM
Balls's Avatar
Balls
i have it too
the butt dyno says +1000hp!!!
hehehe
Old Oct 29, 2003 | 02:33 PM
Xeinth's Avatar
Xeinth
FYI one of those online mags had the JWT generating more HP than a CAI. It still wasnt that much tho.
X
Old Oct 29, 2003 | 03:13 PM
DLin05's Avatar
DLin05
how often should you re oil your filter?
Old Oct 29, 2003 | 03:18 PM
Mikestro's Avatar
Mikestro
Before you replace your filter with a K&N, take your stock filter out if the air box, put your hand behind it, then blow through the filter. You can feel the air through it. Stock filter is already very high flow.
You should read my "which exhaust NOT to get" thread for another after market item that has no measurable affect on performance.
Old Oct 29, 2003 | 03:26 PM
MY350Z.COM's Avatar
I have a strange feeling the factory filter is indeed a K&N. It hasn't been proven, but from the pics I've seen, they look closely similar.
Old Oct 29, 2003 | 03:55 PM
rouxeny's Avatar
rouxeny
Basically, it's DDS, as in, "Doesn't Do S*it." IF, and that's a big if, there are any hp differences, it would be in the very low single digits, as in 1 or 2.
No differences by butt dyno, or real dyno.
Old Oct 29, 2003 | 05:02 PM
DaveO's Avatar
DaveO
While not a 350Z, here's a dyno of a G35 Coupe with a drop-in K&N filter.
Baseline was 233 peak hp. K&N drop-in was 238.3hp.
Sorry about the quality. It never was good, but it got worse when I reduced the size.
Old Oct 30, 2003 | 07:27 AM
K & N recommends to service (cleaning and oiling) every 50,000-100,000 miles on street driven applications. Service more often on off-road or in heavy dust conditions. However, I have heard of people oiling as often as every other oil change.
JjL
East Canada
Jun 12, 2019 03:04 AM
issyz
Jul 2, 2017 03:04 PM
hulkout
Apr 28, 2017 09:00 PM
Justin100
Nov 29, 2015 03:58 PM
codek
Sep 28, 2015 03:03 AM
