Aftermarket valve covers w/ replaceble gaskets
Old Apr 11, 2010 | 02:38 PM
ELMACHOGERACHO's Avatar
ELMACHOGERACHO
i can talk to my parts guy tomorrow and see whats up. what do you want prices on? both covers, gaskets, and plug seals?
Old Apr 12, 2010 | 07:42 AM
Andrei's Avatar
Andrei
This is what happens when the seal was forced out on the VQ35 cover. All those seals I bought was for nothing.
Old Apr 14, 2010 | 09:08 AM
bikinilust's Avatar
bikinilust
subscribing
Old Apr 14, 2010 | 03:50 PM
MR RIZK's Avatar
MR RIZK
I think we need to understand what the root cause is. Is it the seal degraded , the seal shrinking or the OEM clearance between the seal and the spark tube not correct from factory. If the OEM seal is okay the easiest way to fix this could be making a sleeve that goes over the spark tube to seal up the gap between the tube and the seal.
Old Apr 14, 2010 | 06:30 PM
Andrei's Avatar
Andrei
The seal on that cover was hard as hell from the constant cooling and heating. So my guess is that it shrinks as it ages.
Old Apr 15, 2010 | 11:33 AM
Andrei's Avatar
Andrei
Found the QX4/Pathfinder valve cover for the driver side only for now. I only had the passenger side VQ35 cover to match not the driver side bc the online inventory said the junkyard had both. I traced the outline of the QX4 one and went back to the shop and it matches the driver side VQ35 one. The coil packs also use 1 bolt each like the VQ35 one. The junk yard only had the driver side and said they would call me back when they have both.
Old Apr 15, 2010 | 11:55 AM
Andrei's Avatar
Andrei
I ordered the passenger side out of state and I'll go back tomorrow to buy the driver side.
Old Apr 15, 2010 | 01:24 PM
rcdash's Avatar
rcdash
So the Pathfinder has metal valve covers and it fits the VQ35DE and it has replaceable seals? If so, amazing detective work - kudos!
Old Apr 20, 2010 | 11:21 PM
Andrei's Avatar
Andrei
I have both covers now but the passenger side cover doesn't work with the coils from my car. The Pathfinder/QX4 coils are different than the ones from newer VQs. Only way to make it work is to use 1 01-02 coil. I read there are problems with them though.
Gasket fits perfect.
Old Apr 21, 2010 | 06:46 AM
ZRuggernDC's Avatar
ZRuggernDC
Interesting.. What are your thoughts on what to do about the coils?
Old Apr 21, 2010 | 06:54 AM
sloppymax's Avatar
sloppymax
Do you see any grey dots on the coils? The grey dots on the coil was suppose to mark the updated part number that did not have the misfire issues of the earlier coils. I remember this issue from my maxima days.
Old Apr 21, 2010 | 07:15 AM
DaveFunction2ND's Avatar
DaveFunction2ND
Great work!
Also the oil fill is going to need to be modified. I think that's way high. Can you show us how the fitment is on the coil on the passenger side?
Old Apr 21, 2010 | 06:18 PM
Andrei's Avatar
Andrei
Originally Posted by DaveFunction2ND
Great work!
It is high. I guess the hood wont clear. Wont know until install time. From the pic I took you can see the coil is suspended and doesn't meet the surface of the cover so I need at least 1 01-02 coil or possibly all 6. But all other coils do meet the surface of the covers.
I dont have any of the 01-02 coils. I will have to go to the dealer to ask to see those coils and to check for grey dots tomorrow.
Old Apr 22, 2010 | 09:26 AM
Andrei's Avatar
Andrei
Went to the dealer and as I suspected only 1 coil is different then the rest in length. I paid $127 which is really high compared to online prices of 89+shipping which no more than 10-15 for all 6.
This should work now. But wont know for sure until install time.
Old Apr 22, 2010 | 11:39 AM
DaveFunction2ND
It looks like you could possibly just swap the boot over. The soft rubber is two pieces. The shaft portion and then the top cap portion. Maybe swap over the entire assembly or just the shaft portion.
Old Apr 22, 2010 | 11:44 AM
crsracing19's Avatar
crsracing19
so is there an official parts list and # for this modd
Old Apr 22, 2010 | 11:57 AM
Andrei's Avatar
Andrei
I already took one apart and I'm not sure if it works anymore. I'm going to leave it as is unless it misfires.
Old Apr 26, 2010 | 07:32 AM
  #38
BrazenZ's Avatar
BrazenZ
Bump, any updates Andrei?
Old Apr 26, 2010 | 07:08 PM
  #39
johnwigs's Avatar
johnwigs
looks like PCV hoses will be in the way on left cover
Old Apr 26, 2010 | 07:31 PM
  #40
BonesZ33's Avatar
BonesZ33
I have a 2003 with factory seals and 130k on it.. And only one of them is leaking oil. I really don't see the big deal in just replacing it with the factory seals again, they'll last at least another 6 years. Use RTV sealant if it makes you feel any better. Why go through all that trouble.
