Need help on removing rusted exhaust bolts!
Old Apr 11, 2010 | 08:45 AM
CaligrownZ's Avatar
CaligrownZ
Default Need help on removing rusted exhaust bolts!
Anyone know any good ideas? I tried just using socket but not enough torque to break the rust, and my aircompressor isnt strong enough for my gun. There is not enought space with out a lift. I've herd of spraying it with water and than heating it with a torch or drilling the nuts to break them. Will WD work?
Im tried using the search but it cant find the "url"
Old Apr 11, 2010 | 09:05 AM
You sprayed the nuts and bolts the evening before with PB Blaster right?
Old Apr 11, 2010 | 09:34 AM
s31t8n8's Avatar
s31t8n8
soak the bolts with PB blaster overnight
Old Apr 11, 2010 | 09:45 AM
cheshirecat79's Avatar
cheshirecat79
Old Apr 11, 2010 | 09:48 AM
freedonutss's Avatar
freedonutss
Trust me you will use this tool more than once. I got mine for $18 at sears. Please save yourself the trouble and buy one NOAWW
Old Apr 12, 2010 | 08:56 AM
VO...'s Avatar
VO...
Administrator
+1 on all the above. Presoak in PB Blaster, then use the breaker bar. You can use the torch, but the other method should get it...
Old Apr 12, 2010 | 09:09 AM
Z_flip's Avatar
Z_flip
yeah PB blaster... breaker bar... you're all set. Although I've had good luck with WD40, break bar and some MAN power lol
Old Apr 13, 2010 | 09:50 AM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
This stuff is like PB blaster X10. PB is great, but I would be lost without this stuff.
http://images.google.com/imgres?imgu...26tbs%3Disch:1
AbrasiveRaysive
Sep 20, 2021 02:29 PM
sales@czp
Sep 23, 2019 03:30 PM
