Lightened Flywheel Mod Torque Loss
Old Oct 31, 2003 | 05:37 AM
g356gear's Avatar
g356gear
Default Lightened Flywheel Mod Torque Loss
Has anyone lost torque in their cars from changing to a lightened flywheel. Any dyno comparos of stock vs lightened flywheel??
Old Oct 31, 2003 | 05:50 AM
mjedens's Avatar
mjedens
Default JWT Flywheel
I'm in the process of changing to the above while I'm replacing the internals. I'm "spraying a bunch" so I doubt if I see a decrease in my 60 ft. I will be re-dynoing but adding Tomei 268 cams along with flywheel so it might not tell you anything specific about the flywheel.
Old Oct 31, 2003 | 09:51 AM
Ben Davis's Avatar
Ben Davis
Flywheel will not drop torque nor will it really show much (not to its potential) on a dyno cause the gains are proportional to the gear your in, 1st is greatest gains, 2nd is less but still alot, 3rd is minor, 4th is minor if at all, 5th you wont tell a difference.....
MAsSIVrOOM
Oct 20, 2023 10:50 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
