discussion about octane additives
Old Apr 29, 2010 | 06:28 PM
dyna962007's Avatar
dyna962007
Default discussion about octane additives
I'd like to hear some opinions on Octane additives.
I always thought they were useful and although pricey, a way to get into a higher octane fuel thus, less pre-detonation, etc etc.
Some comments on these boards lately have made me think there might be a reason to believe they do not work well.
Tell me your thoughts please.
Mike
Old Apr 29, 2010 | 06:29 PM
terrasmak's Avatar
They are for suckers.
Old Apr 29, 2010 | 06:32 PM
jduet's Avatar
jduet
Buy mods, not octane booster
Old Apr 29, 2010 | 06:37 PM
dyna962007's Avatar
dyna962007
well thanks for the comments but its because of mods, that people need to consider the octane of the fuel.
So, lets get past that.
Assuming a person BECAUSE of the mods, needs high octane fuel, do the octane additives work?
Old Apr 29, 2010 | 06:53 PM
Lets not get silly here.
Old Apr 29, 2010 | 06:54 PM
eltness350's Avatar
eltness350
The Untouchable
just buy higher octane fuel then man, u can get 100/110 and higher if u want and mix with reg gas if u want for ur desired octane or straight 100%...there have been numerous articles proving they do nothing but im too lazy to look for them lol
Old Apr 30, 2010 | 03:03 AM
DavesZ#3's Avatar
DavesZ#3
Mike
I'm curious, what benefit do you expect to gain from using an octane booster?
Old Apr 30, 2010 | 04:25 AM
dyna962007's Avatar
dyna962007
I assume your being serious.
But I think we all know the value of having access to high octane fuel for our cars yes?
Old Apr 30, 2010 | 07:16 AM
str8dum1's Avatar
str8dum1
no please enlighten us. Higher octane does absolutely nothing except waste money unless you have such an aggressive tune that calls for it. One of which you wont reach on a bolt-on car...
Old Apr 30, 2010 | 07:30 AM
dyna962007's Avatar
dyna962007
wow, have you looked at the owners manual for your car?
Does it not call for minnimum 91 octane?
Its well agreed that anytime you can get 93 octane in these engines its a good thing. Now to take that a step further, many mods that you do cause a lean condition, that is fact. Lean causes hotter temps, pinging and dangerous pre-detonation. All facts. The way to combat that is higher octane fuel which was created for the purpose of addressing this issue.
in addition, those of us who have bumped up the timing via a fuel mgmt system once again are looking for as high an octane fuel as we can get.
For those who have timing advanced, and mods, using a higher octane fuel only seems prudent.
That is not my opinion brother, its common knowledge, lets be real.
Mike
Old Apr 30, 2010 | 07:49 AM
DavesZ#3's Avatar
DavesZ#3
Unless you are running some extreme tune (which would be foolish in the first place), or a FI setup, the addition of octane boosters to the premium fuel that is readily available would likely be a waste of money.
We are all aware of the reasons for having high octane race fuels. My curiosity arose from wondering if you really thought you needed it for the mods you have or were just looking to add it to your tank in the misguided belief you'd get more power or there was some other easily recognizable gain that might be had.
Are you experiencing pinging or extreme timing retard? Have you measured or monitored A/F ratio to see if it's actually too lean?
Old Apr 30, 2010 | 07:58 AM
dyna962007's Avatar
dyna962007
Hey I understand.
I agree with you on the additives, I think they are junk.
I was really looking to create a dialog about them to see what others thought.
MY car is tunned and not running lean due to my FMS device.
But may are after mods and not addressing the A/F as you know.
Your points are well taken, mike
Old Apr 30, 2010 | 10:59 AM
Reality350's Avatar
Reality350
Mike
Hey I understand.
Old Apr 30, 2010 | 11:00 AM
dirtbikr's Avatar
dirtbikr
You do realize it would take over 10 bottles of regular octane booster to bring 15 gallons of fuel up just ONE point, from 91 to say 92. Don't waste your money, it doesn't do ****.
Old Apr 30, 2010 | 11:14 AM
gabez33's Avatar
gabez33
not even NOS octane booster!??!?! (looking for autozone receipt)
Old Apr 30, 2010 | 08:20 PM
c0ld29's Avatar
c0ld29
Actually the NOS one raises the octane by 60 points, which = 6 octane numbers (On octane bottles 1 point = 1/10 of an octane), IE 93 octane to 99 octane. (Can't vouch for the actual result, just what they claim)
However thats the only one I've ever seen that actually raises it more than one or two, most say "Raises 10 octane points!" which is really just raising by 1 as others have said.
Old Apr 30, 2010 | 08:41 PM
terrasmak's Avatar
Believe it or not, the Z with normal bolt on will not have an issue with octane. Modern OBD2 computers will adjust for mods, they may not be optimal (like a tune is) but your engine will not be damaged.
91 to 93 octane, they car is tuned from the factory for 91, that means you will gain nothing from going to 93 without a change in tune.
We can actually safely run 89 or 87 in the Z's without problem, there are a few people who only put 87 in theirs without problem. I run 89 in mine on long freeway trips, constant throttle, cruise control set for a couple hours, who cares.
Old Apr 30, 2010 | 08:48 PM
rlw222's Avatar
rlw222
I use stp octane boost . I do not use it where I live because I can get my 93 oct all the time. But when I travel it is a big problem to find anything over 87 in may places in the midwest . My car it tuned for 91 so thats why I have it and yes it does help. It' much cheaper to add 2 btls of this stuff than a 15k engine. This is the only 1 I have found to do anything.
Old May 1, 2010 | 08:34 AM
350junkie's Avatar
350junkie
Originally Posted by dave079
Gotta love people that think that an octane booster raises their octane to whatever it claims. As said above they raise it around a tenth of a point at best.
This.
It's been proven that they don't achieve the claims. Wasted money.
/end thread
