The Crawford Package and JWT/LBMS Package Shootout!
Old Nov 3, 2003 | 10:27 AM
zxsaint's Avatar
zxsaint
Fairlady Stalker
While its true that many variables are introduced on seperate dynos, i'm pretty convinced that the numbers are not too far fetched. On the same dyno day:
Stock Z got 237.
HFM got 255 with intake, exhaust, test pipes.
I got 257 with intake, exhaust, crank pulley
I'll go back to my original theory that the Z is limited at 260 w/ simple bolt-on breathing mods. Without cams & ecu you can swap out every component (intake, plenum, headers. cats, exhaust) and still be at ~260 and will just run lean. That's the cap. The stock ecu just won't compensate for anything over that and you'll need a custom job.
So my advice? Go the least expensive route to 260 ($1000-1200), and then consider cams and a custom ecu program together as a stage II to put you at about 280.
I highly recommend the borla + test pipes + pulley combo. Thats more than enough to put any Z at 260.
Old Nov 3, 2003 | 10:42 AM
nonmature's Avatar
nonmature
Originally posted by KONVERTER
the day every Z dyno's on the same exact dyno im not comparing dyno numbers...
THat same Z that dynoed stock 240 might dyno the same day at 220 on a different dyno...
First off it was an exaggereation, and I was saying that the before and after should be on the same dyno not each car... that way you get at least a somwhat clear picture of how much is gained over stock...
-non
Old Nov 3, 2003 | 02:28 PM
hfm's Avatar
hfm
Originally posted by zxsaint
Stock Z got 237.
X * .85 = 255
X = 255/.85 = 300 hp at the crank!
No more having to say I have 287 horsepower! She's got 300 hp baby!
X = 257/.85 = 302 hp at the crank!
Ditto for you!
And, I agree with you man, this is definitely the way to go.
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
nanotech
Oct 2, 2015 05:02 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
