JWT Flywheel with 300ZX TT clutch
I did a search and did not find anything.
Has anybody used the JWT Flywheel with a 300zx TT clutch pressure plate and disc? I know the flywheel will accept the 300zx clutch, any input on this?
300ZX OEM clutch cost = $240 + shipping, clamping force is 1150 kg compared to JWT 1200 kg for $400 + shipping.
A 300zx TT clutch will not fit on a 350Z flywheel, The pressure plates have a different bolt pattern.
A 90-96 300zx NA clutch will fit on the flywheel but the disk is smaller by 10mm and have much less clamp load and TQ ability. I am also not sure if this set up would clear in the bellhousing as the 300zx pressure plates are taller.
