Need Help with Greddy Oil Block Adapter and STRI
Old May 13, 2010 | 08:30 AM
Blck350z's Avatar
Blck350z
Default Need Help with Greddy Oil Block Adapter and STRI
Hey guys I just installed three STRI Gauges in my center cluster
Here is what I have:
-STRI DSD SLM II; Boost, Oil Temp, and Oil Pres.
-Greddy Oil Filter Sensor Attachment
I test fit everything before hand so I won't have any problems installing items. When I went to test fit the 1/8 PT sensors for the oil temp and oil pres in the greddy block adapter they will not screw in very far (4 complete turns which is about 3/8"). My questions is should they screw in further by hand or is that far enough? On the final install I will use teflon tape and I am hoping that won't make it harder to install.
See the pics below:
STRI Imperial Oil Pressure Gauge @ 1/8 PT and Greddy Oil Block adapter
Rear of greddy adapter... note the picture break down of the parts... the 3 threaded holes are 1/8 pt, 1/8 pt, and M12.
When it is hand tight into the adapter:
I hope to have this setup tonight..... Thanks for the help guys!!
Old May 13, 2010 | 10:02 AM
350z006's Avatar
350z006
I had the same problem, I use a Stri oil temp gauge with the Greddy oil block...I believe the Stri Gauges have SI threads while the Greddy has metric threads...i had to re-tap the Greddy oil block in order to make it work....
Old May 13, 2010 | 10:23 AM
Blck350z's Avatar
Blck350z
I was afraid of having to get an adapter or re-tapping it..... I guess off to sears to get a tap and die set haha
Old May 13, 2010 | 01:17 PM
RandomHer0's Avatar
RandomHer0
Yeah just like their Turbo kits, odds are the fittings they use are BSPT, British Standard, which is a pain in the butt because its very close, but not close enough.
So your 1/8NPT sensor will not fit the 1/8BSPT on the adapter.
You can also get something like this.
http://www.pegasusautoracing.com/pro...asp?RecID=3142
Heres some dude with the exact same issue. Apparently you can get a sensor with a 1/8BSPT.
http://www.iwsti.com/forums/ecu-tuni...vs-1-8npt.html
Old May 14, 2010 | 08:09 AM
Blck350z's Avatar
Blck350z
Thanks for the into "RandomHerO".
These forums are GREAT!!!
I went to a couple local places and got blank stares when I asked the question and showed them the pieces I had... I felt as if I was speaking a different language
Old May 15, 2010 | 05:23 AM
RandomHer0's Avatar
RandomHer0
yeah thats why alot of us are DIY'ers
good luck
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
