87 octane cel p1283
Old May 20, 2010 | 06:21 PM
redlinedifterzx's Avatar
redlinedifterzx
Default 87 octane cel p1283
So I finally had my code read today it came p1283 running lean in bank 2 a/f sensor.
To start off my current mods are cai,5/16 spacer,tps nonfoule, ur pulleys,hks exhaust, rimmed up everything thing else is suspension or exterior
with that being said iv been running tps for about 2-3k no issues when I reset the code last week it took about 300-400 miles for it to throw the code again.
After reading a few threads on the matter it seems alot people just replace there a/f sensor but I don't see that as being the issue unless the sensor it self was dead, I cleaned my maf last week so it should be good I know I need to replace a gasket on my exhaust but that at the opposit end if the car so I'm sure that's not affecting it, I haven't been able to check for exhaust leaks yet either but it I don't smell any other fumes out of the normal with tps
what else should I look into to hunt down the cuplrit to what's throwing the code
Old May 20, 2010 | 07:36 PM
*Boose*'s Avatar
*Boose*
lol, its got to be the ecu advancing or retarding timing. Why are you using 87 oct?
Old May 20, 2010 | 07:57 PM
redlinedifterzx
I'm not this is Just a spin off of the 87 octane thread from last week
Old May 21, 2010 | 04:33 AM
whitelightnin's Avatar
whitelightnin
93 octane FTW
Old May 21, 2010 | 05:48 AM
boosted99gst's Avatar
boosted99gst
This always blows my mind. What's the price difference between 87 and 91/93? 20 cents at best? Filling your tank from bone dry, running low octane will only save you about $3. Not substantial enough to justify the adverse effects it has on the ECU. If you fill up once a week, and can't afford the extra $12 a month, sell your Z and buy something you can afford.
Has a $1500 exhaust yet runs 87 to save $.....
Old May 21, 2010 | 07:32 AM
redlinedifterzx
You guys are missing the whole point if you read the 87 octane thread from last week you might understand that I only used it once out of what I considered to be a bad situation I'm more concered about the code not the .8 gallon of 87 I used on an empty tank
https://my350z.com/forum/engine-and-...ugh-a-cel.html
Old May 21, 2010 | 09:01 AM
J. Dub's Avatar
J. Dub
on an empty tank
You saved so much currency! Way to go!
Old May 21, 2010 | 10:12 AM
redlinedifterzx
*this will be the seconded time I explained it for those that continue to have selective reading *I was running e few miles from my destination fearing I couldn't make it to where I needed to be and not having my wallet on my I had $3 in cash so I opted for the cheaper gas so I could maximize millage even if it's only ten cents more*I was trying to stretch what I had. End story. Like I said I'm more concerned with the p1283 than the gas I used that day the only reason y I put 87 octane in the tittle was becuase I was trying to do a seconed thread on *what I learned from the first hoping to gain more insight on fixing my engine so I don't keep throwing the code. No where in the tittle or anywhere else did I state I constantly use 87 it was a one time thing. Now if you could get passed your selective reading I'd apprciate actuall help with my problem
Old May 21, 2010 | 06:43 PM
jones19d's Avatar
jones19d
im confused on why these dumb ****s cant get it thru their heads that you only used it once ? maybe they just read the title and respond ?
Old May 21, 2010 | 06:52 PM
*Boose*'s Avatar
*Boose*
Shut up noob. Go post in the welcoming board.
Old May 22, 2010 | 02:14 PM
crsracing19's Avatar
crsracing19
no people on this forum just like to flame rather than help the majority of the time
Old May 24, 2010 | 03:24 PM
redlinedifterzx
so can anybody actually shed light on a way to resolve this issue
Old May 24, 2010 | 03:28 PM
0jiggy0's Avatar
0jiggy0
Clear the light, Dont put in 87 octane anymore.
Old May 24, 2010 | 04:08 PM
redlinedifterzx
light came back
Old May 24, 2010 | 04:21 PM
0jiggy0's Avatar
0jiggy0
check for an intake leak
Old May 26, 2010 | 05:48 PM
myfirstzcar's Avatar
myfirstzcar
I've seen cars throw lean codes from running too low on gas, like you were, but it's rare and you'd have to continue running on fumes adding a gallon at a time and turning corners alot for it to happen. They were also saturns and grand ams etc, not a nissan. Look for intake leaks and if all else fails do a fuel pressure/flow test.
Old May 27, 2010 | 08:13 PM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
True that, if you absolutely run the car out of gas, it will likely throw misfire and too lean codes. It's more likely that you have an intake leak of some sort after the airflow meter.
While the car is up to temp and idling, spray some carb cleaner around the plenum and if she idles up or stumbles, that's where your leak is.
If the sensor itself was bad, it would throw a different code.
Bigsyke
Sep 11, 2015 06:19 PM
Darkspy
Sep 7, 2015 09:09 PM
oscarmayer00
Jul 17, 2003 05:26 PM
joandy
May 27, 2003 04:39 PM
chahny
Apr 1, 2003 07:50 AM
