noob gasket question!!!
Old Jun 6, 2010 | 05:41 AM
rips350z's Avatar
rips350z
Default noob gasket question!!!
so i got oil leaking from the top front of my car, what type of gasket do i need for that? is it a crankcase gasket or just value cover gasket?
Old Jun 6, 2010 | 05:57 AM
winchman's Avatar
winchman
More than likely a valve cover gasket. The other major gaskets are the cylinder head (unlikely without other indications of failure) and oil pan (much lower on the engine).
See this:
https://my350z.com/forum/engine-driv...r-gaskets.html
Or do a wider search.
It would probably help if you posted a picture showing where the oil is leaking from.
Old Jun 6, 2010 | 06:22 AM
rips350z's Avatar
rips350z
See this:
figured somone would say that ill go grab the camera thanks man
Old Jun 6, 2010 | 06:36 AM
rips350z's Avatar
rips350z
Default pics
it was hard to take the pic, but as you can see its kinda leaking from around those seals if not that nut down there
Attached Thumbnails noob gasket question!!!-100_3363.jpg   noob gasket question!!!-100_3364.jpg   noob gasket question!!!-100_3365.jpg
Old Jun 6, 2010 | 10:23 AM
winchman's Avatar
winchman
That looks like part of the front cover. You might be able to find the parts here:
http://www.courtesyparts.com/350z-pa...5_716_726.html
Unless it's leaking a lot, I'd just clean it regularly, and let it go.
Old Jun 6, 2010 | 01:01 PM
350ZTheStandard's Avatar
350ZTheStandard
Maybe you can clean up the leak real good and use some clear silicone overnight to seal the leak, Good luck.
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
