if i change 2003 engine for a 2005 aniversary engine !!!
Old Jun 12, 2010 | 11:26 PM
alex350z13's Avatar
alex350z13
Unhappy if i change 2003 engine for a 2005 aniversary engine !!!
i need help !
i got a 350z 2003 , and i broke my crank, so i decide to buy another engine and i buy a 2005 aniversary edition engine... am from dominican republick and y buy the 2005 engine in florida when de engine arrive here i see 2 more sensors than my old engine... am explain in my old engine 2003 i have 2 sensors on de crank and the block don't have, so the 2005 engine have 2 sensors on the crank like de old one and 2 more sensors on the block !
what can i do eliminate the block sensors , can i start the engine !!!
change pieces ???
note: i don't want to buy another ecu and electrical sistem !!!
anyone can help me !!! ?
Old Jun 13, 2010 | 01:18 AM
duro78's Avatar
duro78
You should of bought a de motor as what your experiencing now you will encounnter minor differences between the model year engines.
Old Jun 13, 2010 | 01:30 AM
hellsoldiers08's Avatar
hellsoldiers08
i would get a haltech, i know you dont want to but if you want to keep things simple and easy do it with that or maybe uprev maybe able to help you out.
Old Jun 13, 2010 | 06:17 AM
myfirstzcar's Avatar
myfirstzcar
It is a de motor, but it must be a rev-up de, with vvt on the exhaust side.
Old Jun 13, 2010 | 10:24 AM
johnwigs's Avatar
johnwigs
just use the rear and front timing cover from your DE and eliminate the exhaust retraders... use DE cams (lobe center is different between the cams) and voila!!! you have a DE again... plug the exhaust cam sensors with bad sensors and you dont have to put a connector into them
Old Jun 13, 2010 | 12:28 PM
NISMO_558's Avatar
NISMO_558
I'm curious how someone can manage to break a crank
Old Jun 13, 2010 | 12:33 PM
graffkid732's Avatar
graffkid732
And buying a motor before making sure it's the same. Good luck with the swap.
Old Jun 13, 2010 | 04:36 PM
myfirstzcar
Breaking a crank? Maybe a rod. Maybe his mechanic told him that so he could get the engine off him and change that noisy lifter.
Old Jun 13, 2010 | 09:16 PM
alex350z13's Avatar
alex350z13
someone knows where can i find the diagram of the engine 350z
Old Jun 14, 2010 | 02:59 PM
exZilaration's Avatar
exZilaration
Fixing your grammar might be better
Old Jun 14, 2010 | 04:55 PM
myfirstzcar
He's bi-lingual, spanish then english.
