OS Giken Super-lock LSD Review
Old Dec 7, 2010 | 05:59 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
have you checked the condition of the sensors at each output shaft? they are pretty sensitive
Old Dec 8, 2010 | 05:43 PM
l30thelion's Avatar
l30thelion
Thanks for the heads up, its probably one of the speed sensors, gotta figure out if they just need to be cleaned or if one's gone bad. This post explains the EXACT problem I'm having:
https://my350z.com/forum/brakes-and-...g-braking.html
Old Feb 13, 2011 | 08:51 AM
Bigalow's Avatar
Bigalow
Drivesolo and anyone reading,
I initially used Motul SAE90 with my OS and I've had no problems. I'm going to attend two separate track events in the next two months so I'm already thinking ahead about chaning my fluids. Basically, I'm curious if I should still use Motul SAE90 or go with OS Giken brand fluid "that's made for OS LSDs"
http://splparts.com/store/product-info.php?pid55.html
Anyone think it makes a difference?
Old Feb 13, 2011 | 02:49 PM
terrasmak's Avatar
Never tried the OS oil, but I run amsoil in mine
Old Feb 13, 2011 | 03:18 PM
drivesolo's Avatar
drivesolo
Never tried the OS fluid. The Motul 90 seems to be good for 2 track days and all the driving in between. Seems like you could buy 4x as much Motul for the price of the OS. I dunno if the OS will last 4x as long.
Old Feb 13, 2011 | 03:36 PM
Bigalow's Avatar
Bigalow
I suppose no one has tried the OS fluid because no one is aware of it's existence. You have a point however - frequency will outperform constancy. In other words, I should be fine with motul, amsoil, etc as long as I change the fluid frequently (after X amount of track days). I'll stick with SAE90 since I already started using it. Thanks all.
Old Feb 19, 2011 | 01:31 PM
Honda2Nismo's Avatar
Honda2Nismo
This LSD is not a drop in option for non-LSD pumpkins is it?
Old Feb 19, 2011 | 07:57 PM
drivesolo's Avatar
drivesolo
You might want to check w/ OS Giken, but when I did the install it was only intended for non-LSD pumpkins. They did at the time say that they were working on one for LSD pumpkins. It might be available now.
Old Feb 24, 2011 | 08:09 AM
Z3305's Avatar
Z3305
Default Giken Diff Fluid
I don't know what special Japanese fairy goo is in the Giken fluid, but my experience has been it absolutely eliminates the binding/chattering/hopping on tight, low speed turns. You can use all the best fluids like Amsoil, Motul or Castrol with friction inhibitors but the diff probably won't be quiet.
Giken says you NEVER have to change it out regardless of track use, but I'd probably still do so every 2 years just 'cause that's too hard for me to believe. Giken USA has a long list of dealers on their site where you can find it. I think Z1 also sells it.
Old Feb 24, 2011 | 01:10 PM
Bigalow's Avatar
Bigalow
+1
You'll need the open diff for this LSD unless you get an install kit:
http://www.z1auto.com/prodmore.asp?m...ne&prodid=3489
I think Z1 just sells the LSD with the needed drive shaft.
You're the only one that's commented on that fluid. Do you track your car or daily it?
Old Feb 25, 2011 | 09:00 AM
Z3305's Avatar
Z3305
It's driven most days and also tracked May to October, usually 6-10 (mostly) 2 day events.
Old Mar 2, 2011 | 06:45 PM
HoomanR's Avatar
HoomanR
I also just installed the OS Giken diff in my Z. I drift and its a damn good diff, but then again I have nothing to compare it to bc I have not drifted another z with another diff other than the stock VLSD which for drifting might as well be an open diff
To answer some questions:
You can drop it into a viscous pumpkin or an open pumpkin, you however will need another stub axle(either the shorter stub axle off the stock VSLD or any of the stub axles off an open diff, i used one from a VSLD) its a pretty straight forward install
Fluids: OS Giken recommends their fluid as it is a 80w-250 oil, I would not recommend putting a low viscosity fluid in compared to what they recommend, you will not get the same response.
I used a Royal Purple 70-90 for the first 300 miles, its not a major difference for daily driving but the transitions seemed smoother with the new fluid (however this could all be in my head or it could be the clean fluid)
The fluid is really expensive though as you need 2 cans (2 liters) to do it. So up to you, but the diff is pretty expensive itself
I will be buying an OS Giken clutch soon just bc of how much I liked the diff
Anyhow I am not trying to push this diff because I sell it (if anyone wants any OS Giken parts including oil pm me) but it really is well made....
Old Apr 16, 2011 | 03:51 PM
tibra1's Avatar
tibra1
Unhappy
Originally Posted by Crom
I have yet to track w/ mine yet, but after 1500 miles the slow clunky wheel hop is pretty apparent - I swapped fluids from the motul 75 90 to the 75 140 smurf fluid then added a little friction inhibitor - and this thing is pretty damn quiet now - totally a night and day difference. When track day comes it was suggested to me though to do another fluid swap to irradicate the the additive as running w/ this in a extended performance enviorment might lead to premature wear and possibly unexpected results....As for now, couldnt be happier.
sorry for bumping an old thread here..but for those saying they are get clunk noise etc from their OS Giken LSDs..have you considered that is b/c your are not using OS Giken's gear oil..its an 80w-250 and cost $50 a liter..but worth every penny for smooth and quieter diff operation
Old Jun 6, 2011 | 08:44 AM
drivesolo's Avatar
drivesolo
It's been over a year since I installed the LSD and at least two track days and autoX practice since my last post. LSD is still street friendly and super smooth as it was the day I installed it. I was at an autoX practice this past weekend (7 runs) and still feels amazing. I've put about 5k miles on it so far. The 2 things that I've noticed is that the rear tires are obviously wearing significantly more than the fronts. I would say that since the LSD install they have are wearing at a rate of more than 2x as the fronts and that's the set that only sees street use. I will probably need to replace the rears before the end of the summer at this rate. For my r-comps, where the fronts seemed to wear more than the rears, they now seem to wear at an almost equal rate (combined track & autoX).
I put Redline 75W140 (http://www.redlineoil.com/product.aspx?pid=134&pcid=4) about a month ago and haven't noticed anything from it. Didn't seem to be an issue autoX-ing. I'll be looking forward to seeing how long this lasts.
Old Jun 6, 2011 | 10:11 AM
terrasmak's Avatar
Thats weird, i got longer tire life on the track since i'm not spinning the inside tire up all the time.
Old Jul 3, 2011 | 12:23 AM
pchio's Avatar
pchio
I got the OS Giken LSD for over a year, mainly intense track day use and some driftings. I changed the Diff. oil with red line 75w140 every other track days. Still felt like new and quiet, one of the best LSDs I ever had.
Old Jul 3, 2011 | 12:41 AM
LaoSiFu's Avatar
LaoSiFu
Before the OS Giken fluid what did you use? I would love to make it quieter.
~Robert
Old Aug 11, 2011 | 09:36 AM
  #38
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
So what are the effects of using say a 75w140 oil vs using the recommended 80w-250?
Old Aug 11, 2011 | 01:52 PM
  #39
terrasmak's Avatar
35k on mine so far, no problems
Paul.
Oct 16, 2015 07:34 PM
nanotech
Oct 2, 2015 05:02 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
