Best bang for the buck oil cooler?
Old Jun 24, 2010 | 08:03 AM
jeffie7's Avatar
jeffie7
Default Best bang for the buck oil cooler?
Looking at installing an oil cooler on my car, what's the best bang for the buck kit out there?
Also if a DIY piece together kit is the best option, could you please post links to the random parts needed? No ebay links please.
Thanks!
Old Jun 24, 2010 | 09:14 AM
DavesZ#3's Avatar
DavesZ#3
Start here...
https://my350z.com/forum/engine-driv...r-install.html
https://my350z.com/forum/engine-driv...-pictures.html
I hate to say it, but I spent over $450 on my parts but I went will SS braided Aeroquip hose, reusable Aeroquip fittings, all top-of-the-line stuff. On a budget, you could probably do it for around $350. eBay junk and you can do it for $150-$250.
Old Jun 24, 2010 | 09:22 AM
06blueZ's Avatar
06blueZ
I'v been thinking of going with a dual cooler, oil and replace the factory PS cooler in one..
http://www.summitracing.com/parts/PRM-3311/?rtype=10
Old Jun 24, 2010 | 10:20 AM
NismoZ_840's Avatar
NismoZ_840
Tru-cool or Earls are both value oriented but not no-name/unknown quality vendors. Some great DIYs w/ part# on the 370Z site, google "modshack oil cooler." Just installed a 25 row Mocal in my Nismo, pix/writeup coming soon!
Old Jun 24, 2010 | 10:44 AM
Driven1's Avatar
Driven1
Professional
Jeffie...you can do this yourself pretty easily. The only recommendation I have is go with the nicer stuff like the Earls or something and spend the extra money on fittings and lines. The Aeroquip stuff is really nice as mentioned above.
Old Jun 24, 2010 | 12:53 PM
jeffie7's Avatar
jeffie7
I'm not trying to do it cheap, I'm trying to do the best bang for the buck =)
I'd rather spend 500 on a kick *** setup rather then 800-1000 + on some of the big name ones that most likely wont work any better/worse.
Old Jun 24, 2010 | 12:54 PM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
We don't have lines ready yet for our 350Z kit but this LINK shows our 370Z cooler kits. All stainless braided lines with aluminum swivel fittings, Mocal sandwich adapters, Setrab coolers and brackets.
We're working on a custom bracket that will bolt into factory holes in the core support for the 350Z but our 370Z kits could be adapted to use.
We'll also have the listings up next week for the individual parts for a DIY kit.
Old Jun 24, 2010 | 01:46 PM
jeffie7's Avatar
jeffie7
I highly doubt I could mount it in any normal 350Z spot, I have too much crap in the way, no matter what I bet I'll have to make a custom bracket for it.
Old Jun 24, 2010 | 01:49 PM
DavesZ#3's Avatar
DavesZ#3
If you look in those two DIY threads you'll see that people are mounting them all over the front end. That's one thing about the DIY setup, you buy enough hose to put it anywhere. Some of the kits will limit where it can go by virtue of the length of the supplied hoses.
Old Jun 24, 2010 | 02:01 PM
cdoxp800's Avatar
cdoxp800
I have been looking at doing a oil cooler as well. I have thought about the Z1 one, but There is something already mounted there.
So I search around on my350 here an found some real good threads. I plan on do about the same kind of install as this.
https://my350z.com/forum/2488538-post1.html
But with these parts:
https://my350z.com/forum/1881691-post1.html
Old Jun 24, 2010 | 02:16 PM
240tog35's Avatar
240tog35
Might want to try this Ebay 30 row oil cooler comes with a oil relocation
Attached Thumbnails Best bang for the buck oil cooler?-ebay-30-row-oil-cooler.jpg
Old Jun 24, 2010 | 02:59 PM
VO...'s Avatar
VO...
Administrator
Old Jun 24, 2010 | 03:06 PM
kacz07's Avatar
kacz07
GTM has one. Setrab core, etc. I have it installed on my car.
Old Jun 24, 2010 | 03:11 PM
cdoxp800's Avatar
cdoxp800
Originally Posted by vo7848
You Baller..
Old Jun 24, 2010 | 03:17 PM
iStan's Avatar
iStan
ZR
I say piece it together. You're more than capable of doing it. Depending on space, I have my mounted vertifically within the wheel well. It's bolted in with 8 bolts. It's been holding up fine. Lines are just good old fashion Goodyear and fittings were picked up locally. Sandwhich ordered from summit with just a normal 6x12? core. Only problems I have run into is the lines getting split between the oil pan and sway bar. It's been rerouted over and around the sway bar now, so I'm hoping no new problems.
Old Jun 24, 2010 | 03:28 PM
jeffie7's Avatar
jeffie7
http://www.amazon.com/dp/B000A8FTPS/...S&linkCode=asn
16 row 10an but seems much longer then the ones pictured.
Old Jun 24, 2010 | 04:10 PM
DavesZ#3's Avatar
DavesZ#3
^^^ That's the one I have - it's probably not the actual picture. It's more square than that. The actual dimensions are 8¼x5x2". It looks more like the middle one in this picture...
Old Jun 24, 2010 | 04:13 PM
DavesZ#3's Avatar
DavesZ#3
Got any pics? I'd like to see how you mounted it there. I assume you had to open some ventilation from either under the car or from the sides behind the bumper. Did you enlarge the vent slots in the wheel well front cover and mount against that?
Old Jun 24, 2010 | 04:21 PM
iStan's Avatar
iStan
ZR
I actually removed the reflector for flow in. I cut the wheel liner and expanded the vents to allow for more air flow.
Did the same on the passenger side for the trans cooler
Old Jun 25, 2010 | 02:38 AM
Flo-ridaZ33's Avatar
Flo-ridaZ33
I have yet to install my Stillen... its a setrab core and looks ginourmous. iStan I like the set up.. looks clean.
