SS clutch line installation problem
yeah this is what iv'e heard also... just to keep going with it...but i've also heard of people talking about a pressure bleeder? have you tried something like that before?
Also just as a precaution i would check to make sure there are no leaks anywhere in the system...
i hope someone helps you with this cause i plan on doing this today if the weather permits...
It seems like there was a thread recently where someone said something about adjusting the clutch pedal so the hole in the master cylinder would let fluid/air go up into the reservoir. He said it helped him get the bleeding done.
Has any one experinceed a clunk sound when pressing the clutch? I have the noise for like four engagements then it goes away. I did the stainless steel clutch line and have a comp clutch STG 4 with JWT flywheel.
I Didnt have any issues bleeding the line when I did the clutch install and clutch line. I did bleed it the old school (long process) way and has been fine other than the occasional clunk that eventually goes away.
liqalu04
Jan 2, 2022 12:58 PM
