SS clutch line installation problem
Old Jul 10, 2010 | 03:58 PM
JDMStanced's Avatar
JDMStanced
Default SS clutch line installation problem
i removed the lower end of the stock clutch line but i can't remove the upper one. Through the mirror, i see a clip in between the upper end. My guess is that i have to remove the clip but the damn thing won't move... For the SS clutch line installed guys, how did you remove it?
Old Jul 10, 2010 | 05:36 PM
JDMStanced's Avatar
JDMStanced
I need help ASAP. i need to drive my car tomorrow and the bottom end of thhe clutch line is disconnected in my garage
Old Jul 10, 2010 | 05:58 PM
Wu-Watt's Avatar
Wu-Watt
I'm pretty sure you need a special wrench....
Old Jul 10, 2010 | 06:58 PM
DavesZ#3's Avatar
DavesZ#3
You probably need a flare nut wrench - available at any auto parts store, Sears, Harbor Freight
Old Jul 10, 2010 | 07:21 PM
JDMStanced's Avatar
JDMStanced
i used a flare nut wrench to remove the hard line from the rubber line. But the end of the rubber line won't come off. It's held by a clip
Old Jul 10, 2010 | 07:27 PM
shakuya88's Avatar
shakuya88
Pry bar...have fun, but not too much. Clip is on tight.
Old Jul 10, 2010 | 07:33 PM
JDMStanced's Avatar
JDMStanced
i tried every angle to get it off but no chance.. Could you tell me more specifically how to?
Old Jul 10, 2010 | 08:33 PM
terrasmak's Avatar
Screw driver or small vice grips.
Old Jul 10, 2010 | 08:39 PM
JDMStanced's Avatar
JDMStanced
i assume you know how the clip looks like. It's U-shaped. U letter has 3 tips, right, center and left. Those tips are bent up for some reason.
I tried to grip the center part of the clip that is bent up and pull it away from the hose. It moved a little but no way it'll come off. DO you pull the clip away from the hose by forcing it?
Old Jul 10, 2010 | 10:24 PM
winchman's Avatar
winchman
The clip looks like this?
It's probably corroded, so a little oil might help to get it out. Grip the turned-over edge on the end to pull it off the end of the bracket..
It's shown on page 15 of section CL of the manual (2007 version).
Old Jul 10, 2010 | 10:37 PM
JDMStanced's Avatar
JDMStanced
yeahyeah! that's it. Should i spray some pb blaster around the clip? i checked 05 service manual, CL, and it says the clip is the lock plate
Old Jul 11, 2010 | 05:36 AM
DavesZ#3's Avatar
DavesZ#3
That's the same clip used on the brake lines. All you have to do is grab the tab with pliers and work them off. I realize that space restrictions don't always make that possible or easy
Old Jul 11, 2010 | 05:49 AM
JasonZ-YA's Avatar
JasonZ-YA
Dude, just pry at it, careful not to damage the line.
AcidJake75 and I have done at least 10 cluch installs and line changes to ss lines and this part takes like 10 seconds for us with the following tools:
I have found it best to use curved long needle nose pliers like this to make removal a breeze: (hard to see the curve on the end of these pliers, but it helps)
This pic was taken from elsewhere so ignore the pic message:
Once its off, its a 10mm nut on the hardline, and a small wrench will work if you are careful as there is decent room there, but its super easy with this wrench:
Don't get discouraged, sounds like your freaking out, just work it back and fourth and the clip will come out.
-J
Old Jul 11, 2010 | 09:16 AM
JDMStanced's Avatar
JDMStanced
-J
I was freaking out lol. I tried to wiggle that thing under the car and neck was hurting Now that i know that it is suppose to come off with out doing anything else, i'll go ahead and try one more time thx
Old Jul 11, 2010 | 09:20 AM
JasonZ-YA's Avatar
JasonZ-YA
LOL...........pull on it.........use your prehistoric ancestory monkey grip!!!
-J
Old Jul 11, 2010 | 01:42 PM
JDMStanced's Avatar
JDMStanced
-J
i used my mad monkey grip and pull off that little plate. It felt REALLY good haha.
But now i'm having a problem with the clutch pedal not having any resistance. If i press down the clutch just about where it disengages, it suddenly sucks into the floor by itself. The gear is now stuck at 2nd and it won't go into neutral even if the clutch is pressed in
Old Jul 11, 2010 | 03:17 PM
winchman's Avatar
winchman
From what I've read here, bleeding the clutch system is a really tricky. IIRC, some of the threads about it recommend a pressure bleeder. Do a search.
Old Jul 11, 2010 | 09:49 PM
JDMStanced's Avatar
JDMStanced
i had real hard time bleed that thing. It's 90% done. Took about 2 hrs to bleed and used 2 bottles of 12ml for 90% done haha. But as i was bleeding, i was wondering "why do i have to open and close the bleeder valve so quickly? Can't i just open it for awhile and let the air out?" WHY?
Old Apr 8, 2011 | 11:12 PM
b4tm4n420's Avatar
b4tm4n420
well im no expert but i heard of a good way to bleed the system.
just plug the drain nipple of the slave cylinder at the bottom with a $10 oil can (with a trigger to pump), take out all the old fluid with a turkey baster and then pump in the new fluid from the bottom. air naturally wants to go up...
please correct me if im wrong on the bleed system.
I'm about to do it myself on my z and have just been doing research..
Old Apr 9, 2011 | 06:35 AM
350zion's Avatar
350zion
Professional
I been working on this thing since last weekend... I used the old school method, then the oil can method... It seemed to work but barely... Then I got the car home n parked it n a few days later it was no good again... I used a different pumping method from the bottom up n it felt better.. But here I am days later still with some air in it...
Was gonna try n work on it today n bled again..
Sorry to revive an old thread....
I need to get this done, any one with better ideas chime in.... I've also searched n wat I've found is that I should jus stay wit it...
