Nismo GT Pro LSD help
Old Aug 13, 2010 | 12:51 PM
RA11725's Avatar
RA11725
Default Nismo GT Pro LSD help
Just got the Nismo LSD for my Base Z, it's pre-set to 1.5 way but can be changed to 2-way. My Z is my DD but I also will be learning to drift in it once I get the Nismo LSD installed. I tried a little drifting with the open diff but one time I spun out and smacked a curb so I'm not trying any more until I get this LSD in. I called Function:TUNED in Virginia to see if they could install it for me and they recommended keeping it 1.5 way instead of setting it to 2-way. They told me 2-way is too dangerous for the street. I am inexperienced but is it really that hazardous for the street? Is 1.5-way still good for drifting? Which is safer in rain/snow (If I drive in snow I'll have snow tires though)? Thanks for any info and sorry if it's been covered already...
Old Aug 13, 2010 | 09:22 PM
Wu-Watt's Avatar
Wu-Watt
I have a KAAZ 2-way in my base and I love it. 1.5 is more ideal, but if you want to drift then 2 is the way to go. Do you understand what the difference is between 1.5 and 2 way? A 1.5 will lock under acceleration, and a 2 way will lock under acceleration and deceleration. I'm sure a veteran will step in and explain this better for you.
I think you can get into trouble easier in wet conditions with a 2 way which you would encounter in daily driving, but if your good you'll be fine. I have been for 2 years.
Old Aug 13, 2010 | 10:46 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
If you have no experience drifting then don't set it to 2way. You only need the lock up under deceleration when you are able to use decent corner entry speeds and can take advantage of the rear locking up when you let off the gas. If you use the car on the street and in wet/ice conditions then it will become very unstable. Think about it, your coming off the highway off an off-ramp, and as soon as you let off the gas your back end starts to twitch and before you know it you've lost the back end and hit a wall.
The diff is adjustable so you have nothing to lose. Try it on 1.5way first and once you get used to it and get more experienced at drifting, then you can simply adjust it to 2way.
Old Aug 14, 2010 | 12:28 AM
bardabe's Avatar
bardabe
Rev2Red hit the nail right on the head, just leave it at 1.5way 60% preload and go from there. I daily drive mine and drift on 1.5way its also allot better for time attack.
Old Aug 14, 2010 | 10:37 AM
RA11725's Avatar
RA11725
Cool, thanks for the help guys, much appreciated. I wish it was easier to switch between 1.5- and 2-way. I'll go with 1.5-way to start out and see where that takes me.
Old Aug 14, 2010 | 12:03 PM
Wu-Watt's Avatar
Wu-Watt
Ya really the important thing is to not have a open diff. Wait till you get it in there and you go for a drive. You can get on the gas way harder in corners with a lsd. It's a must. You should also consider a 3.9 final drive set, I have one from 350EVO.
Old Aug 15, 2010 | 10:33 AM
RA11725's Avatar
RA11725
I haven't really looked into the final drive gear sets but that would be something down the road for me. What I really want to do after the LSD is increase throttle response. Idk how to do that but I would love to push the pedal in and not have to wait and predict when the tachometer is going to jump. Just feels like it would make driving so much easier and pleasurable.
Old Aug 15, 2010 | 05:07 PM
Wu-Watt's Avatar
Wu-Watt
Lol.. Look into a Sprint Booster. I have one and I like it.
Old Aug 15, 2010 | 06:20 PM
RA11725's Avatar
RA11725
Sweet thanks man I just read about the Sprint Booster. It modifies the pedal's input to trick the ECU. But is there actually a way to eliminate or bypass the ECU altogether so that there is no delay at all?
Old Aug 15, 2010 | 06:51 PM
HawaiianBBQ's Avatar
HawaiianBBQ
Yeah man that's it, bypass the ECU... That should do it! And don't forget to bypass the master cylinder to increase break times while you are at it... Seriously, do more research on ECU flashing & mapping you'll be able to understand your issue with throttle response from a different level...
Old Aug 15, 2010 | 10:44 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
If you want better throttle response, definitely just get it reflashed. It's a few hundred bucks, and you don't have to hack or modify anything. It all stays OEM.
Old Aug 16, 2010 | 08:57 AM
RA11725's Avatar
RA11725
Thank you rev2red!
nanotech
Oct 2, 2015 05:02 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
