06 Engine Swapped Due To High Oil Consumption?
Old Aug 25, 2010 | 04:24 PM
grimlock's Avatar
grimlock
Default 06 Engine Swapped Due To High Oil Consumption?
I'm looking at a 2006 350z and it had oil consuption issues, so its engine got replaced in 2007. I've read that this is a fairly common problem with 05/06 350z's.
My question: is the engine for this change just a 2007 350z engine?
Also, after replacing the engine, does the oil consumption problem go away?
Old Aug 25, 2010 | 04:26 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
does it have 2 intakes? Whats the seller say about these questions above? If i swap my motor right now in 2010 does that mean ill have a 3.7L engine? Lots of questions
Old Aug 25, 2010 | 05:09 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
No man... I think what he's asking is when Nissan replaces the engine do they replace them with a revised version of the REV up.
Old Aug 25, 2010 | 05:26 PM
xzotklr's Avatar
xzotklr
Nissan will give you the engine for your year.
Old Aug 25, 2010 | 05:49 PM
grimlock's Avatar
grimlock
for your year? Does that mean a 06 z will get a revised 06 engine, or just a new 06 engine?
Thanks
Old Aug 25, 2010 | 06:19 PM
e30cabrio's Avatar
e30cabrio
Mine got an 06 Rev Up with theoretically revised internals that solved the problem. It currently has 13k on it and looses no oil.
Old Aug 25, 2010 | 08:44 PM
Correct. 2006 is the VQ35DE RevUp motor.
2007 is the VQ35HR motor.
Doubt is Nissan replaced the VQ35DE with a VQ35HR.
BTW does a new motor have a 60 month warranty?
Old Aug 25, 2010 | 10:08 PM
Flo-ridaZ33
If Nissan is like Toyota... the answer is likely No.
Old Aug 25, 2010 | 10:37 PM
xzotklr's Avatar
xzotklr
You probably get the remainder of your original warranty.
Old Aug 25, 2010 | 11:06 PM
dmroberson's Avatar
dmroberson
Nissan doesn't replace the entire engine. Just the block. And it's a revised one, for the 06's...
Old Aug 26, 2010 | 06:36 AM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
Pretty sure they get the engines as a complete assembly. Just easier for their techs that way. Had a buddy that did an R+R on an oil consumption deal and they paid him like 8 hours in warrantee time.
The real kicker is that they just toss the old engines right out the back door. If someone was so inclined and knew someone at a dealership, you could get a real steal on an engine ready for a rebuild...
Old Aug 26, 2010 | 07:25 AM
Flo-ridaZ33
+1... Heads and block come as an assembly, or at least thats how Toyota does it. All the accessories come over from the original failed block.
Old Aug 26, 2010 | 07:33 AM
dmroberson's Avatar
dmroberson
+2. When Nissan replaced mine, for oil consumption, the work order said "long block assembly". The rest of the hardware was from the original engine.
Old Aug 26, 2010 | 02:18 PM
This does not sound right. Nissan parts installed by Nissan are good for 12,000 miles. The motor is a part right?
Old Aug 26, 2010 | 02:21 PM
e30cabrio's Avatar
e30cabrio
I was told 10k on mine.
Found out the hard way they installed the exhaust manifolds with a gun. When we did my headers those ***** were HAAAARD to get off!
Old Aug 26, 2010 | 06:38 PM
Flo-ridaZ33
Hmmm... it all depends really. Certain parts have certain warranties.. again I can only speak for Toyota but parts only have 12month warranty.
350z82
Oct 1, 2015 06:25 PM
