No ignition spark..HELP!!!!!
Old Oct 11, 2010 | 11:33 AM
shingr's Avatar
shingr
Default No ignition spark..HELP!!!!!
My car is a 2003 track model.
This car has been in storage all it's life.
It is started and run for a short while.
However, last time I tried starting I heard a whine.. like the starter not engaging.
I charged the battery.. a new one BTW and now it cranks healthy but would not fire.
I had reset the ECU and there are no codes being thrown.
I can hear the fuel pump since I have the rear plastics removed.
I tried shooting starting fluid into the intake but no luck.
I pulled the only accessible coil and got no spark.
I tried a different BCM, ECU and IDPM box...no luck at all.
I reprogrammed the keys each time.
Cranks like hell...
Mods 6 years ago were ported TB and JWT intake..interior has 2007 radio, ac controls with amp..
What is my next step???
Old Oct 11, 2010 | 12:52 PM
DavesZ#3's Avatar
DavesZ#3
I assume tank was drained before storage then fresh gas added before trying to start, correct?
Did you do anything to prime the lubrication system prior to trying to start it? I'm sure after 6 years, all the oil has drained down to the pan and what's up in the engine has turned to goop.
What if any preparations were done prior to storing it?
Next -> Get it hooked up to diagnostics/Consult to find out what's not working.
lolwatbro
Oct 9, 2021 04:58 AM
Katie93
Sep 15, 2015 05:57 PM
cbsuper
Oct 3, 2003 07:41 PM
SandMan
May 15, 2003 01:57 PM
