Engine stalls on the road while on idle
Old Oct 17, 2010 | 02:57 PM
s2kmark's Avatar
s2kmark
Default Engine stalls on the road while on idle
Hi fellow Z owners, my car has been having problems. I come to you for aid.
A month ago, I noticed I was a stop light and the engine would just turn off, I have to crank the ignition about 4 seconds to get it back up. Recently its been occuring more frequently. This time I might've cranked the ignition so many times trying to restart that it caused check engine light to appear. As a result VDC and Slip light are on as well (which I assume it's normal if CEL is on). I reset the ECU, CEL went away until 15 mins of driving it stalled again. I am now afraid of driving it because it has become really hard to restart the car back up.
I got the CEL checked @ autozone and they said its my camshaft position sensor code.
My question is, how do i fix this? What causes the car to stall while on idle? (idles about 700-800) I've seen it stall at 1100 rpm. Will a new camshaft position sensor solve this problem? What caused the sensor to become bad? My battery meter is about 3/4 on the gauge, i dont think its my battery.
Any help is greatly appreciated....
Old Oct 17, 2010 | 04:56 PM
chris05ppwZ's Avatar
chris05ppwZ
This same exact thing happened to me, it is the camshaft sensor. If you replace it the problem is solved.
Old Oct 17, 2010 | 08:21 PM
s2kmark's Avatar
s2kmark
Thanks Chris, I'll try this tomorrow.
Old Oct 18, 2010 | 02:07 PM
zerosec's Avatar
zerosec
+1
had the same problem once...
Old Jan 22, 2011 | 09:56 AM
Onestrainer's Avatar
Onestrainer
I have also had this problem and replaced the Exhaust Gas Sensor and it still happens. The car drives fine it only happens when I come to a stop and not all the time. If anyone has any suggestions please let me know.
Thanks,
liqalu04
Jan 2, 2022 12:58 PM
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
