What's a good brand coolant?
Old Oct 28, 2010 | 09:55 PM
Shawz1102's Avatar
Shawz1102
Default What's a good brand coolant?
What's a good brand coolant to buy? I see prices ranging from $10-$80. According to the service manual we need 50/50 antifreeze. Any suggestions?
Old Oct 28, 2010 | 10:46 PM
dirtbikr's Avatar
dirtbikr
25% prestone non pre-mix and 75% water. My bikes get 25% water wetter and 75% water though... Coolant is coolant is coolant really. If you live in a hotter area that never sees under freezing (like me) then you can run less coolant which makes the system work better. Ideally you would run 100% water as that would be most effective, but you need the lubricity of the antifreeze for seals and the water pump.
Old Oct 28, 2010 | 11:00 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
Water evaporates and adding coolant lowers the boiling point of water in the coolant system, coolant is also a rust inhibitor. If 50/50 is what it calls for than do it... some vehicle manufactures use special coolant ie GM and Honda. I've used factory coolant in my personal experience but most reputable companies do a good job. Make sure that if your in an area that freezes to use Antifreeze if not if you use straight coolant it'll freeze and crack the block(assuming your block doesn't have freeze plugs... i have no idea.)
Old Oct 29, 2010 | 03:19 AM
DavesZ#3's Avatar
DavesZ#3
Get some Prestone Extended Life, mix it 50/50 with DISTILLED water.
Old Oct 29, 2010 | 10:53 AM
JDMStanced's Avatar
JDMStanced
Long time ago, i heard Prestone coolant is crap...can't remember why
Old Oct 29, 2010 | 11:00 AM
06blueZ's Avatar
06blueZ
you should look for a coolant that is Asian vehicle formula. the coolant should be silicate free, and have hybrid organic acids.
http://www.valvoline.com/products/br...antifreeze/105
or just go to the dealer and get the oem nissan coolant.
Old Oct 29, 2010 | 01:16 PM
djraid619's Avatar
djraid619
I agree coolant is coolant. Just remember to use distilled water so you don't get any mineral particles in your cooling system. Also, put in some water wetter.
Old Oct 29, 2010 | 01:24 PM
Bevo's Avatar
Bevo
I just use Nissan green coolant, works for me.
Old Oct 29, 2010 | 01:53 PM
06blueZ's Avatar
06blueZ
... these guys would disagree...
http://www.bobistheoilguy.com/forums...oard=35&page=1
Old Oct 29, 2010 | 07:02 PM
terrasmak's Avatar
I use the green stuff, mixed 50/50 with a splash of water wetter.
Old Oct 29, 2010 | 08:43 PM
omsin523's Avatar
omsin523
50/50 all makes all models prestone should be fine.
Old Oct 30, 2010 | 12:36 AM
cowtown3001's Avatar
cowtown3001
Honda blue coolant has been proven time and time again to be the ish when it comes to aluminum engines.
Old Nov 2, 2010 | 01:27 PM
bbs350z's Avatar
bbs350z
i use evans npg. waterless. expensive, but its good stuff
Old Nov 2, 2010 | 01:41 PM
davboy's Avatar
davboy
I use bottled mineral water with some food coloring to make it green and then a kaleco auto radiator insulator
keeps those temps down!
Old Nov 3, 2010 | 06:08 PM
Nealoc187's Avatar
Nealoc187
Evans NPG
Old Nov 3, 2010 | 06:30 PM
06blueZ's Avatar
06blueZ
Iv read some things about evans that made me second guess it for a street car. It absorbs heat well, but does not release it as efficiently as normal coolant. I have also heard that it is much thicker and has caused premature water pump problems...
do you guys run a pressurized cap with evans?
Old Nov 3, 2010 | 06:39 PM
derekinthez's Avatar
derekinthez
Any decent name brand will do IMHO
Old Nov 4, 2010 | 07:57 PM
kelsey_kaye's Avatar
kelsey_kaye
wtf!
Old Nov 4, 2010 | 09:14 PM
350ZTheStandard's Avatar
350ZTheStandard
I like brand X for other peoples cars. Now don't get excited there, some people swear by brand Y also. It's your call in the end, maybe something green with a 50/50 mix, or maybe you could read the owners manual that came with your car from NiSSan.
Old Nov 5, 2010 | 01:10 AM
dirtbikr's Avatar
dirtbikr
Originally Posted by kelsey_kaye
wtf!
Care to elaborate? Straight water transfers heat much better than a glycol mix could ever hope to. With a 1.4kPa radiator cap, the boiling point of pure water has already reached 240* Fahrenheit. Add in the 25% glycol and the boiling point is brought up further. I don't know about you, but my car never gets over 220 degrees. All the coolant does is raise the boiling point, lower the freezing point, lubricate and prevent rust. Boiling and freezing would not happen to me even if I were to run straight water. The antifreeze has two purposes for me: lubricate and prevent rust. I change it once a year and have not seen a speck of rust in three years on the Z or 14 on the civic. Feel free to finish your statement though...
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
SharX59
Sep 27, 2015 09:23 AM
