Greddy catch can causing vaccum leak
Old Nov 4, 2010 | 10:31 PM
Andrei's Avatar
Andrei
Default Greddy catch can causing vaccum leak
The oil level reading **** is leaking from where the plastic pieces and transparent hose is. I fixed it for now. Is there any solution to this other than plugging the holes with NTP plugs?
Old Nov 5, 2010 | 10:53 AM
Andrei's Avatar
Andrei
This is how I fixed it. I also changed the Greddy hoses out because they got dried up and got brittle.
Old Nov 9, 2010 | 11:07 AM
Andrei's Avatar
Andrei
Another update. Driver side valve cover caused a lot of gas and oil vapor inside the car with the AC on so I put it to vent in the catch can.
Old Nov 9, 2010 | 06:22 PM
winchman's Avatar
winchman
I know zip about catch cans, but it looks like it was intended to be mounted vertically instead of horizontally.
How are you going to know when it's full with the "level reading ****" removed?
I don't understand how oil and gas vapors from the valve cover were getting into the AC system and into the cabin.
Old Nov 10, 2010 | 09:01 AM
Andrei's Avatar
Andrei
Well it doesn't matter. That setup did not work and caused a vacuum leak. I just caught on to it today because it was a very small leak and the RPM was still somewhat steady dropping and raising only slightly but at very long intervals.
The driver side valve cover is venting under the car now.
It catches about 6oz every 3 months or so. I empty it every 2 months.
Old Nov 10, 2010 | 10:55 PM
winchman's Avatar
winchman
How many miles do you drive in three months? What kind of driving?
Old Nov 17, 2010 | 09:25 AM
Andrei's Avatar
Andrei
55 miles per day, on some 100 miles per day. Aggressive driving. On some days I give the car no break at all.
Old Mar 22, 2012 | 03:46 PM
steven350's Avatar
steven350
Back from the dead, can you mount the catch can sideways like that?
sales@czp
Sep 23, 2019 03:30 PM
_bit
Oct 2, 2015 07:49 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
