3.7 or 3.9 Final Drive
Old Nov 15, 2010 | 06:42 PM
nismomike's Avatar
nismomike
Default 3.7 or 3.9 Final Drive
Hey all,
I am about to finalize my next mod! I have a 2008 Nismo, and so far I have X02 Dual Exhaust w/ x pipe, Labree Resonated Test Pipes, Stillen gen 3 intakes and an Osiris tune. I want to upgrade my final drive! 4.08 seems a bit too far stretched for me for the routine driver and such. I don't want to shift THAT much. I was told the 3.7 final drive from the 370z will fit no problem. Also, I am very interested in the 3.9, but the price is very high, but if the increased benefit over the 3.7 is worth it, I will just go that route. What are your opinions? Will I notice a difference with the 3.7? Or should I go with the 3.9? I found a place that will install the gears for $480, providing I provide the gears and the install kit. Thanks!
Old Nov 15, 2010 | 06:49 PM
You can workout the new speeds and shift points using a calculator here: http://www.wallaceracing.com/Calculators.htm
Old Nov 15, 2010 | 06:51 PM
Derek07's Avatar
Derek07
I would suggest the 4.08 as they are so close to the 3.9 and usually less expensive. I have this on my Z, fantastic mod, instant torque multiplier. This mod is something that is VERY noticeable in the butt gauge.
Send a pm to Adam at Z1 Performance, he can set you up, very knowledgeable.
Old Nov 15, 2010 | 07:07 PM
nismomike's Avatar
nismomike
You would recommend this? Is the difference such a way that it can be annoying? Would this be a "lethal" setup for the street, ie. taking off at lights, and possibly a 20 mph pull to 100 mph if i needed to upset some other cars? haha. Also, with a 7600 rpm like my car is set to, what could I expect the MPH in first gear to top out at? 35 mph? or higher? With the governor removed, am I able to go past 160 mph with the 4.08? I agree the 4.08 is more feasible regarding price...
Old Nov 16, 2010 | 05:13 AM
Kwame's Avatar
Kwame
The term "annoying" is purely subjective. Some people consider driving a car with only two seats as being annoying.
The answers to your other questions can be answered by you doing a little leg work of your own. A gear ratio calculator like the one I believe DavidV posted above (admittedly I did not click on the link he posted) is all that you should need.
Old Nov 16, 2010 | 05:19 AM
KingBaby's Avatar
KingBaby
Hardest Setting
searching is to damn hard!
Old Nov 16, 2010 | 09:09 AM
nismomike's Avatar
nismomike
The link brings me to a bunch of various tools, I'm not entirely sure which one to click? I think I am just gonna go with the 3.9 Upon reading many outside sources from other forums, its a solid way to go.
Old Nov 16, 2010 | 09:50 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
https://my350z.com/forum/4390297-post1.html
3.9 works fine, but it is much more expensive than the 4.08 and not typically stocked in the US anymore. 4.08 is a small change (4%), in stock, and far less costly...and it compliments the HR perfectly
Old Nov 16, 2010 | 11:46 AM
nismomike's Avatar
nismomike
I found it on vividracing.com's site for 579.99. Even if its not in stock, they say they can ship it from japan. But for the price, I think thats very very fair. Just pick up an Install Kit for 30 bucks and call it a day.
Old Nov 16, 2010 | 03:59 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Just let me know if you'd like to order it
Old Nov 17, 2010 | 05:03 PM
kramykram's Avatar
kramykram
LOL just go with the 4.083. I have just built another differential with it for my car and I am in love all over again. Just need some wider rubber to hold her to the ground. =X maybe some better tires.
Old Nov 17, 2010 | 07:30 PM
Steve-O Z33's Avatar
Steve-O Z33
I have the 4.083s waiting for install. All I need are for my bearings to get here. The shop that is building mine wouldn't do it without all new seals and bearings.
Old Nov 17, 2010 | 08:04 PM
kramykram's Avatar
kramykram
i just reused my old bearings. they seemed fine. had less than 20k miles on them. just ordered new seals and crush sleeve. you are gonna love them.
Old Nov 17, 2010 | 08:25 PM
AVmagneticZ's Avatar
AVmagneticZ
if you usually do around 80-85mph on the highway you wont be doing that anymore with the 4.08 and thats where it becomes a tad bit annoying if you are making a 30 min trip to work or something on the hwy. really depends on your driving i guess but this mod is great makes driving the car a bit more fun cause ur sliding when u stomp on it in second. you kind of notice that you are shifting more often (sooner). but all around definetly go with the 4.08 or bare minimum 3.9. i mean if your going to make a difference u might as well feel it and get the 4.08. i dunno what else i can say here if you have questions let me know ive had the 4.08 for a few months now.
Old Nov 17, 2010 | 10:13 PM
kramykram's Avatar
kramykram
8 hour drive to atlanta with my 4.08 with no problems. depends on how loud your exhaust is. lol putting the silencer in took care of that problem right away.
Old Nov 18, 2010 | 01:04 AM
dwrecckk's Avatar
dwrecckk
I have pondered this myself lately. I guess the real question is, at what RPM are each of the gearsets at 80mph? Stock 3.5 is around 3k, I've heard that 4.08 is around 3400RPM?
Old Nov 18, 2010 | 01:42 AM
KingBaby's Avatar
KingBaby
Hardest Setting
Originally Posted by ACEMAN
Let me first say.... This is by far the BEST mod i have done to my NA car...
You turbo guys will understand ( remember the chills that went up your back when you first drove your FI car?? ) Thats me
First, 2nd and third gears are amazing. The car pulls sooo much harder now. I cant wait to get it to the track rental next friday. I have my ECU reflashed to the 7200 Rpm Redline.
Here is a break down of the STOCK gear ratio's
1st Gear Ratio: 3.794:1
2nd Gear Ratio: 2.324:1
3rd Gear Ratio: 1.624:1
4th Gear Ratio: 1.271:1
5th Gear Ratio: 1.000:1
6th Gear Ratio: 0.794:1
-Reverse Ratio: 3.446:1
This is calculated using 255/45/17 Tires
http://www.f-body.org/gears/
STOCK 3.357 Gear-- ECU REFLASH 3.357 ---HR Engine
6600 Rpm Redline --------7200 Rpm Redline----------7500 Rpm Redline
First------40mph ------First-----44mph-----------First-----46mph
Second ----66mph ------Second----71mph-----------Second----74mph
Third------94mph-------Third----102mph-----------Third----107mph
Forth-----120mph-------Forth----131mph-----------Forth----136mph
Fith------152mph-------Fith-----166mph-----------Fith-----173mph
Sixth-----192mph-------Sixth----209mph-----------Sixth----218mph
STOCK 3.538 Gear-- ECU REFLASH 3.538 ---HR Engine
6600 Rpm Redline -------7200 Rpm Redline-----------7500 Rpm Redline
First -----38mph ------First-----42mph-----------First-----43mph
Second ----62mph-------Second----68mph-----------Second----71mph
Third -----89mph-------Third ----97mph-----------Third----101mph
Forth ----114mph-------Forth----124mph-----------Forth----129mph
Fith -----144mph-------Fith-----158mph-----------Fith-----164mph
Sixth ----182mph-------Sixth----199mph-----------Sixth----207mph
No Reflash 3.7 Gear-- ECU REFLASH 3.7 ----HR Engine
6600 Rpm Redline ---------7200 Rpm Redline---------7500 Rpm Redline
First -----36mph-------First ----40mph-----------First-----41mph
Second ----59mph-------Second----65mph-----------Second----68mph
Third -----85mph-------Third ----93mph-----------Third-----97mph
Forth ----109mph-------Forth----119mph-----------Forth----124mph
Fith------138mph-------Fith-----151mph-----------Fith-----157mph
Sixth-----174mph-------Sixth----190mph-----------Sixth----198mph
No Reflash 3.9 Gear -- ECU REFLAH 3.9-----HR Engine
6600 Rpm Redline ----------7200 Rpm Redline-------7500 Rpm Redline
First ------35mph-------First ---38mph-----------First-----39mph
Second -----56mph-------Second---62mph-----------Second----64mph
Third ------81mph-------Third----88mph-----------Third-----92mph
Forth------103mph-------Forth---113mph-----------Forth----117mph
Fith-------131mph-------Fith----143mph-----------Fith-----149mph
Sixth------165mph-------Sixth---180mph-----------Sixth----188mph
No Reflash 4.083 Gear-- ECU REFLASH 4.083--HR Engine
6600 Rpm Redline ------------7200 Rpm Redline---------7500 Rpm Redline
First ------33mph--------First ---36mph----------First-----38mph
Second -----54mph--------Second---59mph----------Second----61mph
Third ------77mph--------Third ---84mph----------Third-----88mph
Forth ------99mph--------Forth---107mph----------Forth----112mph
Fith ------125mph--------Fith----137mph----------Fith-----142mph
Sixth -----158mph--------Sixth---172mph----------Sixth----179mph
Here are the track results
Vid
http://www.youtube.com/watch?v=S8ZTsAgCabw
Link to thread
https://my350z.com/forum/drag/307682-new-best-13-064-105-5-all-motor.html
Before and after the 4.083 gears
let this not go to waste!
Old Nov 18, 2010 | 07:53 AM
AVmagneticZ
I would kill myself going on a drive longer then an hr and have to do less then 120kmh cause at 130 which is about 85mph the car revs at 3500 cruising at that rpm i dunno im not an expert but doesnt feel safe who knows. Depends how u drive i guess
Old Nov 18, 2010 | 07:54 AM
AVmagneticZ
The 4.08 at 80 is like 3400
Obadabot
Jun 18, 2023 11:31 PM
3vilbunny
Jul 18, 2017 05:10 PM
350z82
Oct 1, 2015 06:25 PM
