Power steering loss while passing?
Old Dec 8, 2010 | 08:34 AM
Wipe_Drive's Avatar
Wipe_Drive
Default Power steering loss while passing?
On the way to take a final yesterday i passed a car (i think i hit 80-85 in 4th) and the power steering died... a red light came on the dash directly underneath where the tps light is. It went off about the time i saw red and i regained power steering... any thoughts, other than pass in 5th next time?
Old Dec 8, 2010 | 08:36 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
your gear selection had nothing to do with it
if the pump regained its power assist, the belt is intact (i'd check it anyway for cracks, wear just to be safe). You could be really, really low on fluid (indicates a leak), or your pump could be on its way out. Either way, it needs attention
Old Dec 8, 2010 | 08:45 AM
Z Infidel's Avatar
Z Infidel
That red light is a shift light, nothing to do with your warning/indicator lights.
Old Dec 8, 2010 | 11:48 AM
winchman's Avatar
winchman
Are you sure it wasn't the speed-sensitive power steering just doing what it's supposed to do?
Old Dec 8, 2010 | 11:59 AM
Z1 Performance
Former Sponsor
power steering doesnt die and then suddenly come back on a properly working system
Old Dec 8, 2010 | 02:02 PM
Sorry but I don't believe it.
Old Dec 8, 2010 | 07:51 PM
Wipe_Drive's Avatar
Wipe_Drive
thanks... power steering fluid is full and the belt is starting to crack so hopefully when that gets replaced itll take care of it... and yes it did happen... you can drive it if you want
Old Dec 8, 2010 | 10:14 PM
winchman's Avatar
winchman
What makes you think the power steering quit working? I doubt you were trying to turn the wheel more than a few degrees at 85mph, but anything is possible when you're already driving like an idiot.
In Georgia, it's illegal to go over the speed limit to pass someone, and going 85mph puts you in the "super-speeder" category, which carries some hefty fees in addition to the already-high speeding fine.
Old Dec 9, 2010 | 04:59 AM
Z1 Performance
Former Sponsor
I would think anyone with brain can tell when their power steering completely goes out...it's not a subtle feeling
when you're changing the belt, you may want to inspect the pulley and see if there is any play or wobble to it
Old Dec 9, 2010 | 05:06 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Please go to www.toyottapriusisforf@gs.com and stay there. Ok, thanks.
Old Dec 9, 2010 | 06:22 AM
Z Infidel's Avatar
Z Infidel
Great input. Good thing he's not in GA then.
Old Dec 10, 2010 | 06:07 AM
Wipe_Drive's Avatar
Wipe_Drive
you are correct sir, it wasnt a sharp curve... however it was enough to make me sh*t myself when the steering wheel wouldn't move... but seeing as your in that commie state of Georgia I guess you don't understand how people in normal states drive.
Old Dec 10, 2010 | 06:09 AM
Wipe_Drive's Avatar
Wipe_Drive
+1, yea i'd hate to live there
Old Dec 10, 2010 | 06:16 AM
Wipe_Drive's Avatar
Wipe_Drive
I just had the belt replaced, the heater wasnt working until I got to 2500-300rpms so when i took it in i had them replace the belts as well. they said one was starting to crack and the other one was worn out... on the bright side... i now have heat and new belts
Old Dec 10, 2010 | 07:56 AM
shakuya88's Avatar
shakuya88
Did they say which one was worn out? I'm thinking it was the P/S alt belt, and the belt just slipped, giving you no power steering and the battery light (red light you said) Then you got it all back when you shifted (no torque, belt grabbed)
Old Dec 10, 2010 | 09:57 AM
Z1 Performance
Former Sponsor
cool - hopefully that solves it permenantly
ablaine
Nov 29, 2016 10:13 AM
