Outcome Predictions needed (HR Cams)
Old Jun 23, 2011 | 09:27 AM
  #121
MM'08_350Z's Avatar
Why do I have the worst of luck!!!! The techs started up the car this morning and it started making a noise!!!! I asked if it was valvetrain noise but he said he wasn't sure so it's being thoroughly inspected. Crossing my fingers I hope there is nothing wrong.
Old Jun 29, 2011 | 04:54 AM
  #122
kramykram's Avatar
kramykram
wow man sorry to hear about the bad luck. let us know.
Old Jun 30, 2011 | 06:34 AM
  #123
MM'08_350Z's Avatar
Try to tell me what you guys see wrong here guys.
Old Jun 30, 2011 | 07:09 AM
  #124
midz350's Avatar
midz350
I'm sure your mechanic knows this, but usually engines after major overhaul make loud noises until the oil go up to the valvetrain and lubricate everything.
Also, its normal for built VQ's (and sometimes stock ones) to make loud valvetrain noises.
Old Jun 30, 2011 | 07:17 AM
  #125
Zazz93's Avatar
Zazz93
Don't like the red stuff (looks like some odd lube) but if you look closely, you'll see one valve is opening while the other is not. This leads me to believe the valves aren't shimmed correctly (too tight) and possibly others are too loose. The loose ones just make noise while the tight ones can burn up a valve and hurt an engine.
Old Jun 30, 2011 | 11:46 AM
  #126
QTB's Avatar
QTB
Bingo! I'm not sure what kind of PTV clearance the HR has but that could make it end poorly. It would certainly cause a tapping sound.
The only thing I find curious is this noise was discovered after a day of tuning. I would initially think it would be noticed right away. I'm not real familar with the top end on the VQ but could this be a sticky HLA?
Old Jun 30, 2011 | 12:05 PM
  #127
Zazz93's Avatar
Zazz93
Nah... it should have made the noises immediately. I can only imagine they may have thought it was a basic valvetrain noise or maybe thought it would go away after the oil worked it way through the system. Another possibility could deal with the variable vavle timing getting stuck. Can't say for sure.
Old Jun 30, 2011 | 03:00 PM
  #128
MM'08_350Z's Avatar
Well find out very soon (tomorrow). The techs said that maybe a spring failed and the reason for the sound was that the Cam lobe was not riding on what ever it's supposed to be riding on it was slapping it.
Old Jun 30, 2011 | 03:24 PM
  #129
SurraTT's Avatar
SurraTT
DAng sorry to see this!
kinda makes you think "needs bigger injectors"
Old Jul 7, 2011 | 01:15 PM
  #130
biggersNISMO's Avatar
biggersNISMO
Bump
Old Jul 7, 2011 | 02:20 PM
  #131
Italianjoe1's Avatar
Italianjoe1
In for final outcome...
Old Jul 7, 2011 | 03:40 PM
  #132
kramykram's Avatar
kramykram
+1^
Old Jul 8, 2011 | 08:16 AM
  #133
MM'08_350Z's Avatar
Well guys the bad news... I mean, the horrible news is that they found Metal shavings in the oil filter. What they said that failed was the dual valve spring so that valve effed up my head so i don't wanna risk it any more with that block and those heads, so I went ahead and bought a brand new Motor from Courtesy Parts ($7200) so right off the bat this project is a fail my 10-15k spend on this project. But I'm still going to install the camshafts by themselves with no aftermarket Valve-train, Blue350Zed has similar cams with stock valve-train and had an awesome N/A Z with good Power.
Old Jul 8, 2011 | 10:55 AM
  #134
biggersNISMO
Wow, I can't imagine how you feel. What a deep loss.
Old Jul 8, 2011 | 10:59 AM
  #135
QTB's Avatar
QTB
The spring failed after a few hours of use, and a dual spring to boot?!?!?!?!? WTF! I'd be raising a little hell with the manufacturer.
Old Jul 8, 2011 | 11:07 AM
  #136
kramykram's Avatar
kramykram
dude dont buy a new one i have a used one with 30k miles on it for a good price. very good price. pm for details. ill even deliver it to you
Old Jul 8, 2011 | 12:38 PM
  #137
Zazz93's Avatar
Zazz93
Sorry to hear man, worst part about it... the HR's valvetrain was probably strong enough stock. Could have been a defective spring, but its also possible it was installed incorrectly or over-rev'ed. Any-how, I think your new plan is fine and should yield great results (just make sure the stock springs are compatible with the lift).
Old Jul 8, 2011 | 04:26 PM
  #138
MM'08_350Z's Avatar
How can I find out if my stock valve spring can handle 11.0mm of lift? They say that stock valve springs can handle even up to 12mm lift cams but I might be wrong.
Old Jul 9, 2011 | 04:30 AM
  #139
Zazz93's Avatar
Zazz93
Tough to say, Jim Wolf cams suggests changing them out for their 11.9 cam (stock is 10.54). Where-as, Tomei suggests the DE and HR is expected to be ok upto about 11. Tough one... I'd look for peolpe like Blue350Zed and see what they have been able to get away with as well as talking to some of the manufacters' tech depts.
Old Jul 31, 2011 | 02:58 PM
  #140
biggersNISMO
Outcome?
