Engine Torque Specs
Old Jan 30, 2011 | 08:21 PM
BabyZiLLa's Avatar
BabyZiLLa
Default Engine Torque Specs
Can someone help me understand the Service Manual torque specs?
Is it giving me a range? Saying within that range is acceptable? So if I'm reading it right it is saying anything between 64-85 inch-lbs?
Old Jan 30, 2011 | 10:26 PM
BabyZiLLa's Avatar
BabyZiLLa
Really? Noone knows?
Old Jan 30, 2011 | 10:33 PM
BlackFaytZ's Avatar
BlackFaytZ
yup
Old Jan 30, 2011 | 10:35 PM
BabyZiLLa's Avatar
BabyZiLLa
Originally Posted by BlackFaytZ
yup
What is "yup" supposed to mean?
What do the other numbers represent?
I swear this forum use to be a lot more helpful. Guess all the 350z guys have moved on to bigger and better toys.
Old Jan 31, 2011 | 06:18 AM
juelz86z3303's Avatar
juelz86z3303
All that means is that the torque specs must meet with in that range of numbers that was given to you. 65lbs is the minimum to torque that specific bolt and 85 is the max.. nothing lower than 65 nothing more than 85 lbs of torque.. . torque wrench. can dail in the specific torque that is required by the fsm. This will ensure u of no broken bolts or studs due to not over torquing the bolts unlike regular ratchets..
Old Jan 31, 2011 | 06:20 AM
BabyZiLLa's Avatar
BabyZiLLa
Appreciate it mate. Didn't realize they had such large variations that were acceptable?
So what do the other numbers mean? I would have thought lb-feet but that is represented by different icon in the key.
Old Jan 31, 2011 | 07:54 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
those are other measurements for torque.
maybe you shouldn't be wrenching?
Old Jan 31, 2011 | 07:59 AM
BabyZiLLa's Avatar
BabyZiLLa
I think I'll be fine. Thanks for your concern.
What I didn't get is why have two different key icons for lb-ft and lb-inch when you are going to include both on every bolt.
Old Jan 31, 2011 | 08:03 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
They don't include them on every bolt. They list a range, 5-10 and the symbol tells you whether that is in-lb or ft-lb.
And just so we are clear there is a factor of 12 difference between the two.
Old Jan 31, 2011 | 08:05 AM
BabyZiLLa's Avatar
BabyZiLLa
Makes sense. I've got it. Thanks.
Old Jan 31, 2011 | 09:49 PM
drivessidewayz's Avatar
drivessidewayz
The "yup" answered your question. You were correct in your assumptions, so he was answering the only relevant question at that point. No reason to imply insults regarding his simple answer to your simple question.
7.2 - 9.7 = N*m
.74 - .98 = kg*m
64 - 85 = in-lb
Old Feb 1, 2011 | 09:47 AM
kelly350Z's Avatar
kelly350Z
Hey babyzilla what are you torquing? The entire engine? I will be soon. Just got back from home depot and got some bolts to fasten a full long block I got 4 days ago onto an engine stand. I will tear it down, take it to get the bottom end built and then assemble everything following these same torque specs you ask about.
This forum is hugely invaluable on the amount of info it has. It just takes lots of reading and digging around old threads sometimes to get the specific info you are looking for.
Oh and don't mix those torque specs up. Like they say... measure twice and cut once.
Old Feb 2, 2011 | 04:00 PM
BabyZiLLa's Avatar
BabyZiLLa
Thanks for the help guys.. I've got it all sussed and dialed in the new torque wrench..
I have another Q though regarding the service manual. Is there any way to get a PN for a bolt or screw etc? The service manual shows the bolt and torque specs but no PN, if say you loose one. How would you find out the correct bolt?
Do I need FAST?
Fixxxercask
Nov 9, 2015 11:10 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
