Is there a problem with my transmission?
Old Feb 15, 2011 | 06:30 PM
Yura's Avatar
Yura
Default Is there a problem with my transmission?
Hi guys
I have an 05 350z Touring with a manual transmission. A few days ago I began to notice my rpms spiking and my cruise control glitching. At around 68+ mph (i noticed it happen at 68, 70, 73 mph, etc) as im holding down lightly on the gas, my rpms would just spike from around ~2700 rpms to like ~3500 rpms. I am consistently and lightly giving gas and the rpms just spike at a certain MPH. I think this is what cause my cruise control to glitch too because if im cruising at for example 70 and i accelerate it by 1 nudge, the rpms spike and cruise control shuts off.
What can this be? Should I change my transmission fluid?
Old Feb 15, 2011 | 06:53 PM
sportbiketed's Avatar
sportbiketed
Kinda sounds like your clutch is slipping.
Old Feb 15, 2011 | 07:05 PM
Welcome. There are several excellent "How to diagnose a slipping clutch?" threads. Worthwhile reading.
Yura's Avatar
Yura
I'm not even switching gears or using the cluth when this happens that's why it is so strange. It feels as though I have just switched gears... it actually feels as if it were an automatic because as i accelerate, the rpms go up rapidly for a second as if the car just changed gears.
Old Feb 15, 2011 | 07:29 PM
350ZTheStandard's Avatar
350ZTheStandard
r u running traction control, when this happens & is this the original OEM clutch?
Old Feb 15, 2011 | 07:52 PM
Yura's Avatar
Yura
well vdc isn't off. But it still does it even if i turn it off.
The clutch is the original oem i think
so this can actually be the clutch even though I am not shifting?
Old Feb 15, 2011 | 08:14 PM
sportbiketed
The clutch only slips when its engaged...
Old Feb 15, 2011 | 08:25 PM
terrasmak's Avatar
The clutch holds the power of the motor to the trans, if the clutch is weak , it will slip. Google how a clutch works.
Old Feb 15, 2011 | 08:51 PM
Yura's Avatar
Yura
exactly what I thought... but when I'm in 6th gear driving on the highway im not touching the clutch or transmission at all
Old Feb 15, 2011 | 08:59 PM
R350Zz33's Avatar
R350Zz33
are you really asking these questions buy a clutch done deal. pretend the clutch is a road with a patch of black ice your tires never lift off but you still slip (your tires are still engaged to the road) you clutch is worn out and when it catches that bad spot it slips. get it got it good if you still dont get it ask the 15 year old next door to you .
Old Feb 15, 2011 | 09:22 PM
sportbiketed
Foot on pedal=clutch disengaged
Foot off pedal=clutch engaged
Is this your first manual?
Old Feb 16, 2011 | 05:17 AM
Yura's Avatar
Yura
Thanks guys, I'll get it replaced. Sorry about the questions... I really should read more about how all this works haha
Old Feb 16, 2011 | 05:28 AM
JasonZ-YA's Avatar
JasonZ-YA
clutch is out! op, take some time and read some how to articles and youtube vids on how the mechanics of the clutch works, etc.......from there, watch and read any other related articles........you can learn a bunch..
good luck on fixing your car....
welcome..
-J
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
