unorthodox pulley question
Old Nov 26, 2003 | 01:11 PM
KISS's Avatar
KISS
Default unorthodox pulley question
what's the difference between the ultra s and ss??
Old Nov 26, 2003 | 01:17 PM
MY350Z.COM's Avatar
Ultra S contains the crank pulley only.
Ultra SS contains the whole 3 pulley set. (Crank, Water Pump, Alternator)
None of them come with belts.
Old Nov 26, 2003 | 02:44 PM
KISS's Avatar
KISS
what's better?
Old Nov 26, 2003 | 04:22 PM
MY350Z.COM's Avatar
Ultra SS since it lightens the other pulleys as well.
Old Nov 26, 2003 | 04:35 PM
Boomer's Avatar
Boomer
OK, dumb question. If the underdrive pulley gains power, then it is robbing it from other systems in the car, right? If yes, then it makes the air conditioner less effective and work harder. Is there a component longevity problem down the road as those systems have to work harder? Every action has a reaction, is the increased parasitic loss to other systems negligiable?
Old Nov 26, 2003 | 05:35 PM
MY350Z.COM's Avatar
I don't think it makes the other components work hard; I think they just work less effectively. i.e. the air conditioner does not blow air as hard.
The reason why I have no doubts on the pulleys from UR is because I've read about Maxima (VQ30DE) owners having these pulleys for over 100,000 miles w/o any problems to any component of the vehicle.
Victor
Old Nov 26, 2003 | 09:03 PM
Boomer's Avatar
Boomer
Default pulley
So I'm partially correct, the efficiency of other systems is somewhat reduced, but probably not a wear problem in the long term. Thanks, Vic.
Old Nov 26, 2003 | 09:08 PM
MY350Z.COM's Avatar
No prob Keith.
Happy Thanksgiving!
edit: I forgot to clarify that the UR pulleys actually free up power that is being used by accessories. It doesn't help the engine produce any more power. It makes more of the existing power get to the ground.
Old Nov 26, 2003 | 09:42 PM
FLY BY Z's Avatar
FLY BY Z
There will be no change in how hard the AC blows. There will be an impercebtible difference on how cold it gets though.
Old Nov 27, 2003 | 08:06 AM
Boomer's Avatar
Boomer
No prob Keith.
Happy Thanksgiving!
Makes sense. Thanks and Happy Thanksgiving to you too.
Old Nov 27, 2003 | 08:08 AM
Boomer's Avatar
Boomer
Got it. Thanks, PH. Happy Thanksgiving.
Old Nov 30, 2003 | 08:15 PM
jckolnturn's Avatar
jckolnturn
What about alternator function and the dimming of the lights while sitting still at a light? do you get any of that with the UR pulleys?
Old Nov 30, 2003 | 08:37 PM
Mapleleaf's Avatar
Mapleleaf
Default UR Pulleys
Have them on mine for 3 months , only the crank pulley is smaller the others are the same size ,only light weight , and have not noticed any dimming of lights or air conditioning problems at all
350Zteve's Avatar
350Zteve
Underdrive pulley's actually extend the life of your accessories. since the spin slower, they spin less which equals longer life. As for your A/C and alternator, etc., they only noticable decrease in output would be at idle. A typical alternator is giving its maximum output at about 1500 engine rpms. A/C the same.
issyz
Jul 2, 2017 03:04 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Alexreyes
Sep 30, 2015 11:30 PM
