some weird symptoms
Old Mar 1, 2011 | 08:09 PM
CaliBoy's Avatar
CaliBoy
Default some weird symptoms
So here is a list of some weird symptoms:
Vehicle has a hard time starting
Shuts down when car warms up and will not start till it cools down (a few hours later)
oil in the air filter housing (coming from throttle body)
oil on spark plugs (on the combustion chamber side)
getting the following codes: misfire and all cylinders
throttle actuator incorrect.
vehicle is in limp mode, half the power and service engine light is on. i took out the spark plugs and cleaned them but after reinstalling and running the car for a min or two they are oily again.
any ideas as to where i should start? i am hoping its not the valve rings...
Old Mar 1, 2011 | 08:47 PM
winchman's Avatar
winchman
How many miles on the car? Engine mods? Driving style? What's it sound like when it's running?
Without more info, I'd GUESS that oil is getting into the induction system through a bad crankcase ventilation valve, but high mileage, a modded engine, aggressive driving style, and unhappy noises could easily change that diagnosis.
Old Mar 1, 2011 | 08:50 PM
CaliBoy's Avatar
CaliBoy
39k miles on the car...no mods all stock...driving it conservatively. it does not sound very good when running. it runs like its misfiring (which it is)
Old Mar 2, 2011 | 04:19 AM
AJCaron12's Avatar
AJCaron12
Oil in the plugs is usually a sign of bad valve cover gaskets.
Old Mar 2, 2011 | 07:20 PM
winchman's Avatar
winchman
The OP says the oil is on the combustion chamber side of the spark plugs, so that's not it.
Old Mar 3, 2011 | 08:09 AM
AJCaron12's Avatar
AJCaron12
The combustion chamber side could be bad rings too but I doubt that's the case here too.
Old Mar 3, 2011 | 08:22 AM
winchman's Avatar
winchman
A stuck PCV valve would cause a pressure buildup in the crankcase, which could be forcing oil past the valve seals.
Is the exhaust showing any blue or black smoke? Are the tailpipes sooty or wet? Are you sure it's oil on the plugs instead of being really wet with gasoline?
aarrgghh
May 1, 2022 11:04 AM
Uriyo_
Sep 8, 2021 08:46 AM
pslamp32
Feb 8, 2017 09:07 AM
kyin
Oct 15, 2015 05:54 AM
hulkout
Tuning
Sep 18, 2015 05:42 AM
