Oil pressure question
Old Mar 2, 2011 | 05:49 PM
ibboatin28's Avatar
ibboatin28
Default Oil pressure question
I'm new and yes I did a search but... I just picked up my first "Z" Monday and love it. My question is above 2-4K rpm the engine carries 60+psi. At idle it drops below 30. Is this normal for an engine of this type? The oil was just changed at the dealer. No mods on the car, seems unmolested and was has been serviced by the dealer since new.
Thanks in advance...
Old Mar 2, 2011 | 06:03 PM
sportbiketed's Avatar
sportbiketed
Yes
/thread.
Old Mar 3, 2011 | 09:09 AM
Boba's Avatar
Boba
What about cruising at 70 mph in 6th gear? Does it stay around 90 or so? And when you WOT, does it hit max 120+? If yes, then it might be a faulty oil pressure sensor. Also, idle psi after warmed up should stay at 30 psi, not below.
Old Mar 3, 2011 | 10:00 AM
Ixyl's Avatar
Ixyl
Service manual states oil pressure should be >14 psi, at idle, when the car is at operating temp (oil temp = 176F). Mine (06), when warmed up, reads 15 psi at idle and 60-70 psi @4k+ RPM. When the car is cold it will read ~30 psi at idle and up to 120 psi @4k RPM until the oil starts to warm up.
Old Mar 3, 2011 | 01:56 PM
ibboatin28's Avatar
ibboatin28
Thats about what mine is. So they are either both normal or both defective. I'm used to the old days when 15-20 psi meant loose bearings. Thanks for the assistance guys.
Old Mar 6, 2011 | 03:25 PM
sssmasss's Avatar
sssmasss
i think it is normal bro. either that or my z and ur have faulty gauges! hahah
Old Mar 7, 2011 | 04:15 PM
MKZ33's Avatar
MKZ33
It's normal
issyz
Jul 2, 2017 03:04 PM
Vigman
Nov 17, 2015 04:34 AM
nanotech
Oct 2, 2015 05:02 AM
Inspatatrac
Sep 8, 2015 02:12 PM
