Help please
Old Mar 7, 2011 | 01:22 PM
anibalvega's Avatar
anibalvega
Default Can i used an 06 engine with an 05 harness?
Can any one tell me if I can use a 06 rev up engine with my hardness from an 05 non- rev?
What about the plugs conectors in front of the time chain cover?
Old Mar 7, 2011 | 03:06 PM
Just a suggestion. Put a subject in the subject line like
Squeaking brakes
instead of
Help
Need help immediately
If you don't help right away I will die!
Old Mar 7, 2011 | 03:13 PM
anibalvega's Avatar
anibalvega
thank u
Old Mar 7, 2011 | 03:15 PM
anibalvega's Avatar
anibalvega
Davis thank you!
Do you know if I can use this rev up engine on my 05 z harness?
Old Mar 7, 2011 | 03:28 PM
anibalvega's Avatar
anibalvega
Davis thank you I did edit it and change it but I havent seing the change yet!
Do you know if I can use this engine with my old 05 harness?
Old Mar 7, 2011 | 04:10 PM
terrasmak's Avatar
Yes but no. Yes you can, but you need to convert the motor to a non-rev to work.
Old Mar 7, 2011 | 04:18 PM
anibalvega's Avatar
anibalvega
Can you explain it how can I do it, I have an 06 engine but because of the cam sensors in the front of the timiming chane cover I m not sure if it will work right!
Any help I will appreciate it
Old Mar 7, 2011 | 04:29 PM
terrasmak's Avatar
Change cams to non rev, install your current front timing plate and intake cam sprocket to new motor, get blockoff plugs for the back of the rev up head. Install in your car.
Old Mar 7, 2011 | 04:52 PM
anibalvega's Avatar
anibalvega
Thank You for your help
