Thanks For towing then frying my Z - Please help!
Old Mar 15, 2011 | 11:17 AM
jetster's Avatar
jetster
Default Thanks For towing then frying my Z - Please help!
My car was jumped by a towing company recently, and now I can't start the car. From what I gather they switched the wiring on the cables, which cause a dead short somewhere. Scanner is reading nothing from the ECU. Any ideas? The Z shop locally estimated me 1k - 1500 depening on time to diagnose the issue. This also comes with programming new keys, and an extra set.
Thanks for the help!
Old Mar 15, 2011 | 12:06 PM
terrasmak's Avatar
Fuse 2 inches from battery terminal? Is it blown?
Old Mar 15, 2011 | 12:56 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Also check the fuses behind the battery....there was one i couldnt find cause it looked good but was really blown.
Old Mar 15, 2011 | 07:17 PM
jetster's Avatar
jetster
Ill check tomorrow, if it's not the fuse, any other ideas? Nissan tried to program a key, but they couldnt get a signal from the ECM, any ideas?
Old Mar 15, 2011 | 07:46 PM
winchman's Avatar
winchman
If they hooked the jumpers directly to both battery terminals or to the positive terminal and ground, it wouldn't blow the fusible link. Most of the current would be going straight into the battery, not into the car's electrical system.
The bad thing is that the reverse voltage from the other battery would be higher than that from the one in the car, and that would put a reverse voltage (probably less than 12 volts, though) on the car's electrical system. Sounds like that was enough to do major damage.
At least the battery didn't blow up.
Dr.Paulyy
Jul 29, 2019 07:45 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
ILoveDrifting
Sep 7, 2015 03:15 PM
slay2k
Jun 23, 2003 05:37 AM
chicago350z
Feb 9, 2003 01:55 PM
