draining and removing air conditioner - a/c
Old Mar 26, 2011 | 02:37 AM
Bigalow's Avatar
Bigalow
Default draining and removing air conditioner - a/c
I never use my a/c and I’m going to remove it. I know it’s against the law to remove the Freon so I’ll pay someone to drain it. I checked courtesyparts for a few diagrams and figured I would wing-it but I’d rather follow a guide instead. Can someone point me to a good DIY?
Old Mar 26, 2011 | 06:49 AM
AJCaron12's Avatar
AJCaron12
Don't remove your A/C. I did it before with my old Mustang, hardly worth it at all. And it made it harder for me to sell the car
Old Mar 26, 2011 | 08:07 AM
Bigalow's Avatar
Bigalow
Sorry, I forgot to mention that my Z is my track vehicle. I don't daily it and don't plan on selling (for another 6-10 years).
Old Mar 26, 2011 | 08:18 AM
0jiggy0's Avatar
0jiggy0
Its pretty self explanatory. The compressor and condenser are bolted in and buried. Be prepared to take everything off in the front to get the condenser off. It should help with airflow to the rad I suppose. The lines are probably more trouble then their worth to shed half a pound. The evaporator if its like most vehicles will make you want to kill your mother since most of the dash has to come out. That probably isn't worth it either. Id focus on the compressor and condenser and cap off any electrical connections to prevent corrosion and any future problems.
Old Mar 26, 2011 | 10:12 AM
AJCaron12's Avatar
AJCaron12
I pulled the compressor and used a dead pulley in it's place. Pulled the condensor and cut the lines out to make the job easier. The evaporator I left alone.
Old Mar 26, 2011 | 11:11 AM
KornerCarver's Avatar
KornerCarver
You don't have Freon in your A/C. You have R-134A refrigerant which is environmentally friendly.
Old Mar 26, 2011 | 01:39 PM
AJCaron12's Avatar
AJCaron12
I disagree with this statement. The gas is still commonly referred to as freon, and it is safer to the atmosphere than the old gas called R-12. People used to release R-12 into the atmosphere until they discovered the harm that it causes, so now R-134A is used. BUT! the 134 should still be collected with proper A/C recovery machines and should still NOT released into the atmosphere.
Old Mar 26, 2011 | 01:41 PM
Bigalow's Avatar
Bigalow
Good advice. After looking it over at courtesyparts and googling some stuff, I understand the amount of work involved with removing everything. I may just remove the compress and condenser. I'll probably have to snip some lines (rubber/metal) that are leading into the compartment. It's ok to just cap everything off, right?
Is that a fact? I spoke to a 'mobile mechanic' and asked if he can remove freon from my vehicle. He told me that it's a $50K fine to remove it anywhere other than a shop (I suppose it's a Virginia law). If R-134A is safe then does that mean I can drain the system myself?
Old Mar 26, 2011 | 01:45 PM
AJCaron12's Avatar
AJCaron12
The freon in your a/c systems must be recovered with the proper machine at the garage and not released into the atmosphere.
Old Mar 26, 2011 | 01:46 PM
Bigalow's Avatar
Bigalow
Noted... you posted as I was replying to the previous posts.
Old Mar 26, 2011 | 01:50 PM
SpoilsofWar's Avatar
SpoilsofWar
R134 is still illegal to knowingly vent to atmosphere, as per the clean air act...
I did it, cause global warming is BS. Its freaking 20 some degrees here today and its almost april
I deleted my A/C (also a track car), but had to leave the gutted compressor housing on the block because the TN kit uses it as a mounting point. However, you dont need to leave a pulley and run a belt to it. Heres my setup:
here you can see the leftover housing and the new belt route:
Old Mar 26, 2011 | 04:31 PM
Bigalow's Avatar
Bigalow
At the moment my compessor isn't even connected to my crank. I cut the belt. My setup is now exactly like your pix.
what is R134? Gas or liquid?
Old Mar 26, 2011 | 04:39 PM
AJCaron12's Avatar
AJCaron12
It's the gas in your A/C system.
Old Mar 27, 2011 | 04:58 AM
Bigalow's Avatar
Bigalow
Default 2003 350z Owners Manual
Not harmful but illegal. Page from my 03 owners man.
File Type: pdf
Old May 6, 2020 | 07:43 AM
Kylie81's Avatar
Kylie81
I personally feel silly when I read that kind of threads, lol I didn't understand almost anything except first comments. Guys, I guess, you are more smart in all these stuff, can you suggest me the best aircon repairing service(speaking of airons). I've just managed to discover really highly-rated servicing(www.socool.sg/) , but I still have some doubts. Could you suggest anything? My aircon is seeping all the time and this oily water seems to be not ok.
Old Jun 3, 2020 | 06:00 AM
Steve Granger's Avatar
Steve Granger
I would prefer to hire cooling and heating contractors when seeing such issues when an ac unit or need to remove the ac unit.
burglapfd
Dec 6, 2020 01:04 PM
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
