DESTROKING is it possible and how?
Old Apr 23, 2011 | 01:47 AM
usarmy1113's Avatar
usarmy1113
Default DESTROKING is it possible and how?
Ok so I have seen threads about destroking a vq35hr and everyone always takes over the thread and says oh DONT DO THAT. Then I hear about the possibility of using a vq30dett crank and making the 3.5 roughly a 3.2. So my goal with this is that possible. Do you have to get custom rods? I am going to go boost and will likely do a custom single turbo. I want to do this so dont tell me how stroked motors can rev to a hundred thousand rpms.
Old Apr 23, 2011 | 02:16 AM
0jiggy0's Avatar
0jiggy0
Sounds like you have all the answers. Go talk to your machinist.
Old Apr 23, 2011 | 06:54 AM
WTFMike's Avatar
WTFMike
If you are looking to boost your car, then why not just have the bottom end built with aftermarket rods and lower compression pistons?
Old Apr 23, 2011 | 07:59 AM
Frostydc4's Avatar
Frostydc4
With a shorter stroke & the piston height unchanged I would think so
Old Apr 23, 2011 | 10:37 AM
bigcloud's Avatar
bigcloud
You have to ask yourself the question what is the car going to be used for and how much money you have budgeted. Do you want to do this to have a unique show car? Or are you going to race it? Or are you going to daily drive it? You have a lot of research to do...
Old Apr 23, 2011 | 12:03 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Aw, man... I read your title wrong... I though it said:
D Strokin, is it possible?
I was completely off base, sorry... Sparkle OUT!
Old Apr 23, 2011 | 12:23 PM
midz350's Avatar
midz350
Why would you want to do that? SRS.
Old Apr 24, 2011 | 05:41 PM
qqqqball's Avatar
qqqqball
make it rev higher faster,
I had see it done, he used a custom crank ~ $4k had to notch the motor out due to stroke was so big, custom Rods ~400 $each, Custom pistons ~$300 a pop, was a 13:1 compression, o ringed heads, no turbo, custom comp cams, sheet metal intake, darton sleeves . reved to 11k no problem, but was a straightline car. was roughly a 3.2 liter. was it worth it... up to the customer.
Engine builder was Rico Recine, old owner of motion in L.I., out of New Milford, CT.
Old Apr 24, 2011 | 05:43 PM
qqqqball's Avatar
qqqqball
if you were to go the turbo route, big bore short stroke is the better option, not small bore short stroke thats more of a n/a high rev build.
Old Apr 24, 2011 | 09:19 PM
bbs350z's Avatar
bbs350z
^cha ching. the faster the spool, the more usable rpm range. destroking will increase lag, and your higher revving would be almost the same as having a less laggy higher output motor
Old Apr 25, 2011 | 07:29 AM
Lawn Dart's Avatar
Lawn Dart
As we all know, horsepower is a product of torque and RPM. Most high revving engines are spinning faster to produce more RPMs, which through gearing can be converted to more horsepower. Unfortunately, torque suffers. Therefore, it's best suited for lighter applications, like karts and motorcycles. Our heavy car requires torque. You're wasting your time.
Old May 6, 2011 | 09:53 PM
Nealoc187's Avatar
Nealoc187
it's doable and has been done. fairly pointless imho unless you are building for a race series that limits your displacement or you just want to say you did it (which I can understand, frankenstein builds are cool in some ways).
other things are going to start being and issue before you get to the point where you would actually benefit from the shorter stroke of a 3.2 frankenstein motor over a stock throw 3.5. Even though the 3.5 is a "stroked" VQ30, it's still got a short frickin stroke. piston speeds are still really low.
Old May 7, 2011 | 12:34 AM
seymore4's Avatar
seymore4
Professional
ROFL
usarmy1113
Jul 19, 2012 07:02 PM
vqman
NA Builds
May 30, 2012 12:07 PM
08NismoZ
Dec 8, 2010 12:32 PM
widerisbetter
Aug 9, 2007 11:43 AM
