Clutch pedal has a lot of play all of a sudden
Old May 20, 2011 | 08:14 PM
bencurtis's Avatar
bencurtis
Default Clutch pedal has a lot of play all of a sudden
Im on vacation, but right before i left my clutch pedal started acting up on my 06 350z. It has the stock cluctch, flywheel and shifter etc. While driving the clutch pedal went from an inch or so of free play at the top of the stroke to almost half of the entire stroke of the pedal. It still engaged and disengaged correctly, didnt feel or hear sny grinding, rpms were where they should be for speed and gear, except one time when shifting from 3rd to 2nd it just kind of slipped out of 3rd and into 2nd, just didnt feel right, that was right before i got home, and i havent driven it since. Does anybody have any ideas, suggestions? Also, any good import transmission shops around Augusta, i usually take my car toarc younts for standard work but i dont think he does transmissions.
Old May 21, 2011 | 03:46 AM
2000atlanticgt's Avatar
2000atlanticgt
Have you checked the clutch fluid reservoir to see if it is low?
Old May 21, 2011 | 06:42 AM
bencurtis's Avatar
bencurtis
No I actually never thought of it just beingnlowon fluid, ill have to chek that when I get back home. I haven't seen it leaking any fluid, no wet spots in my parking spot at work or my garage. Could it "burn through" clutch fluid?
Old May 21, 2011 | 08:46 AM
2000atlanticgt
No, it will not burn clutch fluid but the level should be checked as step one in my opinion. Once you check the fluid level I would also try bleeding the system.
Old May 22, 2011 | 10:26 AM
Andrei's Avatar
Andrei
It could be the slave cylinder on the transmission, mine is out and the clutch pedal gets stuck half way to the floor and I stall the car sometimes because of it. It could also be the pivot ball or the throw out bearing.
Old May 29, 2011 | 01:14 PM
bencurtis's Avatar
bencurtis
hmmm... I checked the fluid level, it's just a hair below max, I think I'm gonna have to bring it in and get it looked at, I've got an extended warranty and I believe they'll cover a lot of this, just have to see how much of it they will cover.
Old May 29, 2011 | 08:04 PM
terrasmak's Avatar
Sounds like the clutch master is sticking, very common problem.
Old May 29, 2011 | 08:19 PM
StraySheep's Avatar
StraySheep
I am sure the dealer won't be of much help because this problem only occurs when the car is driven under hot/warm weather after 20+ minutes of stop and go tracffic.
Once your car cools down, the clutch pedal will be back to normal. But then the problem will come back again under the same driving condition.
I suggest you drive your car until the pedal has a lot of free play or get stuck half way. Then got to the dealer and have the tech come out to see the problem right away. Or else once you leave the car with them, when it's time for the dealer tech to check your car, he will tell you there's no problem with the clutch pedal because your clutch line has already cooled down.
By the way, before you change anything, try bleeding the clutch line a few times or as many times as need to get the clutch fluid to be as clear as new fluid. If that doesn't solve the problem, it is THEN you look into getting the clutch master cylinder replaced.
Good luck.
Old May 29, 2011 | 09:25 PM
lbz's Avatar
lbz
My 05 slave cylinder went bad, had similar problem. Dealer replaced under extended warranty.
Old May 30, 2011 | 05:23 AM
bencurtis's Avatar
bencurtis
Ok ill check into it! Thanks everyone!
Old May 31, 2011 | 07:05 PM
sry110's Avatar
sry110
Same exact thing happened to me this evening. It was about 85 degrees out and I did some stop and go driving with a few downshifts thrown in there, and after about 15 minutes of driving I noticed the same symptoms. After every shift the pedal would not spring back to normal height so I would pop it back out with my toes. When I got the car home and parked it for a half hour, I went back out and the clutch pedal seems to be back to normal (still a little sticky, but does pop all the way back out).
I think I'll take this to the dealer and just describe to them what is happening. I also have an extended warranty so hopefully they play ball.
Old May 31, 2011 | 07:08 PM
terrasmak's Avatar
Its the master, gunk is built up in it, needs to be disassembled and cleaned, rebuilt or replaced.
I like the rebuild part, $15 in parts from Nissan, and 2 hours of time if you have limited mechanical knowledge.
Old Jun 1, 2011 | 05:58 AM
sry110's Avatar
sry110
Is there DIY around here for how to do that, and bleeding the clutch fluid?
Old Jun 2, 2011 | 07:17 AM
bencurtis's Avatar
bencurtis
I just put mine in the shop... hopefully they don't hose me on costs..
sherm
Apr 11, 2020 05:21 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
