Revup shortblock questions
Old 06-10-2011, 02:19 AM
acke15
acke15's Avatar
Default Revup shortblock questions
So I have a opportunity to buy a low compression built shortblock. coming from a 03 g35, will it fit on my revup motor.
I was going to use my stock heads if possible. I wasn't for sure if I could do the non revup short block or not.
Old 06-10-2011, 08:17 AM
bmccann101
bmccann101's Avatar
id just call Import Parts Pros.. they build engines, they could tell you EXACTLY versus random forum members like myself who could only stand to feed you half truths.
Old 06-10-2011, 08:24 AM
bmccann101
bmccann101's Avatar
all I can offer you at this time is thier ph number ( I.P.P., 281-288-0700) and this:
Enjoy, and good luck.
Old 06-10-2011, 08:29 AM
Premier MemberSuper Moderator
terrasmak's Avatar
Received 2,333 Likes on 1,681 Posts
I know you can use a rev up block and heads with DE cams for a DE, i don't know about going the other way. I also know there is something different in the oil pan area do to the cosworth baffle set. Don't know how it would effect the build.
07-10-2022 07:44 AM
issyz
07-02-2017 03:04 PM
Quick Reply: Revup shortblock questions
