New Lightweight Flywheel, hard to drive?
Old Jun 17, 2011 | 09:54 AM
nscheuermann09's Avatar
nscheuermann09
bmccann, just saying, for real you have the most badass Z I think I've ever seen. Very well done.
Old Jun 17, 2011 | 10:44 AM
bmccann101's Avatar
bmccann101
Thx man. It'll have over 600 HP soon. Then it will deserve the compliments ha. UNtil then its a pretty pile of dead weight.
Old Jun 17, 2011 | 11:35 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
clutch dragging.. solved by bleeding / pedal adjustment?
pedal adjustment
Old Jun 17, 2011 | 11:36 AM
bmccann101's Avatar
bmccann101
well there it is then.. thx for the reply.
Old Jun 27, 2011 | 02:56 PM
MitsuHybrid's Avatar
MitsuHybrid
Originally Posted by nscheuermann09
I was driving it around today, and twice when coming up to a stop sign going around 5 mph, i tried to shift into first (clutch pedal all the way to the floor) and it ground the gears when I tried to put it in?
Why are you shifting into first when your deceling for a stop sign? Breaks dont work? Thats just asking for trouble. But just give the gas a little bump while clutch is in and pressure is on shift lever into first gear; a few RPM's will help if its your sincs. Still shouldn't be shifting into first though.
Old Jul 1, 2011 | 06:29 AM
bmccann101's Avatar
bmccann101
updates.. bought a new cd0-09 trans to hopefully solve the problem.. and if thats not it, then this is:
the shifter must be adjusted when reinstalled due to changes in part locations from reinstallation of everything.. needs to be adjusted in a specific way..starting in 6th gear, moving back aligning and tightening as you go.. i dont have the thread link.. and it appears alot of techs are not aware of this need.
Search shifter plate adjustment on google. youll find it fast.
good luck.
Old Jan 21, 2012 | 09:11 AM
lilpud's Avatar
lilpud
i have a problem kinda like this. i just had my stock clutch and flywheel replaced w/ a stage 4, 6 puck compition clutch w/ light weight flywheel. im having problems getting into gear. has been bleed 3 or 4 times, and we adjust the pedal twice.. idk? wasnt having this problem before? any ideas? thanks
and when im locked out of gear.. i mean all of them, gotta blip the trottle and sometimes that doesnt work
Old Jan 22, 2012 | 06:22 PM
STL 350Z's Avatar
STL 350Z
Great... this thread is making me nervous about doing my clutch/flywheel install next weekend. I have read the install DIY here many times and I have been studying the service manual. Now I am having reservations.
Old Jan 23, 2012 | 06:17 AM
lilpud's Avatar
lilpud
ehh even tho im having slight problems, i still wouldnt go back to stock if that tells you anything..?
Old Jan 23, 2012 | 07:22 AM
STL 350Z's Avatar
STL 350Z
I'll be installing the Exedy OEM clutch and ACT Streetlite flywheel. I'm mechanically inclined so I shouldn't have any issues if I mark the locations of everything before I start.
Old Jan 23, 2012 | 10:05 AM
chillah7889's Avatar
chillah7889
well I think I can add myself to this list. JWT clutch and lightweight flywheel installed within the last week, started having problems getting into gear as well. Still pretty prevalent now, had the clutch line bled several times and pedal adjusted by mech and by myself as well. Should have plenty of time this weekend to play around with the pedal adjustment a ton and see if that helps.
Old Jan 23, 2012 | 01:54 PM
STL 350Z's Avatar
STL 350Z
I'm actually starting my install tomorrow since it's supposed to be warm for 2 days.
Jesus take the wheel.
Old Jan 23, 2012 | 10:00 PM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
Some bad info in here
A clutch, if set up properly, should gain clamp load for the first 50% of clutch wear, After that it will slowly lose clamp load as the disk wears the rest of its life out.
A diaphragm style clutch will gain pedal effort as it wears. If you start the clutch at maximum clamp load you would never get full life out of the disk.
Maximum clamp load can only be achieved in one spot of the diaphragm or "belleville" spring, go either way in or out and clamp load falls off.
Obadabot
Jun 18, 2023 11:31 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
