RT cat owners: are you running lean?
Old Dec 14, 2003 | 09:41 PM
  #41
12SecZ's Avatar
12SecZ
I'm reflashing for my cats and pulleys up in Torrance after Christmas. If I left b4 then I may get killed lol.
Old Dec 15, 2003 | 04:18 AM
  #42
350Zzzz's Avatar
350Zzzz
Professional
Originally posted by 12SecZ
The white on the ceramic is showing a lean condition yes. Look at the ceramic part not the metal.
It is not Cheston's personal plug.
AnywayZ's is there any update on this with the stock setup RT cat only who was in snow?
Thanks. I am not ruling out a reflash but I wanna do a few other things first then roadtrick (ugh)
A chalk, white porcelain insulator usually indicates a lean condition, hot plugs (incorrect heat range), pre-ignition stage; and Metallic specks, would indicate that you're moving up stihs creek.
This site does suggest that lean running engines could also be caused by exhaust system
G
Old Dec 15, 2003 | 05:53 AM
  #43
CarFanatic's Avatar
CarFanatic
In reading this post it seems to me that the people running lean have the ts ecu, fi or cams. Now its common knowledge that with a tuned ecu, fi or cams, anytime you open the exhaust up it will cause the car to run lean. I guess I'll wait to see if someone with a stock ecu and basic bolt ons runs lean. Also if that was the case I would think that any type of cat replacement would cause the same problem. Unless maybe the rt cats aren't flowing as well as they shold creating more heat and then creating a lean condition?
Old Jan 2, 2004 | 05:14 PM
  #44
alex30327's Avatar
alex30327
Default Re: RT cat owners: are you running lean?
I'm confused? According to the NGK site, your plugs are normal. The pic that NGK provides seems like a lean condition to me as well. Any experts on plugs here?
Here is NGK's description
Normal Condition
An engine's condition can be judged by the appearance of the spark plug's firing end. If the firing end of a spark plug is brown or light gray, the condition can be judged to be good and the spark plug is functioning optimally.
Originally posted by Chebosto
This is just a query to all those that have RT Cats-
if you have time, please check your spark plugs and post the color of them around the plug heads...
over the weekend we pulled the plugs on a Z before he went in for an ECU reflashing to see if the rumor was true. the Z had cams, nismo intake and nismo exhaust and the RT cats.. although the other mods *might* have caused the plugs to turn white... we're still suspecting its the cats.. since this is the second or third case we've seen on RT cat owned vehicles...
here's a couple pict of the plugs... kinda of a bad angle-- the back of the plugs were fairly white..
just wanted to see if this was another fluke-
please check if you have time..
thanks--
Cheston
Old Jan 2, 2004 | 07:43 PM
  #45
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
I am running soo lean with my RT Cats / K&N Typhoon / NISMO Cat Back that I have this really thick black stuff on my exhaust tips...
I try cleaning it off, but by the time I get to work it is back again...
hehehehe
I am being sarcastic if no one could figure that out... about running lean.. I am running quite rich...
Old Jan 3, 2004 | 10:03 AM
  #46
alex30327's Avatar
alex30327
hehehehe
Jason,
Will an intake manifold leak cause the engine to run lean? My car died on me the other day, and then would not crank till I re-installed my plenum. I had taken my plenum off the other day, and I am positive that I had all the hoses connected well. I checked my plugs, and they look very similar to this.
Old Jan 3, 2004 | 10:10 AM
  #47
Wedge's Avatar
Wedge
Talking I saw that really thick black stuff.......
.....on Jason's exhaust tips in person. He is either running really rich............or it is the result of the two quarts of oil he has to put in his car every day...........lol J/K
Old Jan 3, 2004 | 10:28 AM
  #48
flynnibus's Avatar
flynnibus
Z Flier
Originally posted by Z-*****
If the ecu is following a static fuel map then it would have to be adding more fuel for increased flow. Otherwise no one would be making any power from ANY mods.
He means at WOT the car is in open-loop.. which means its not looking at the o2 sensors to adjust a/f (no feedback = open loop). The car is just going off its pre-determined fuel maps.. there is no feedback from the o2 sensors adjusting that statically defined map.
Old Jan 3, 2004 | 03:03 PM
  #49
ttsupra94's Avatar
ttsupra94
HOw much does it cost to get the ECU flashed? How are you guys getting your A/F ratios? Do you have A/F meters or is that just from Dyno's?
Old Jan 3, 2004 | 04:11 PM
  #50
Ultimateone's Avatar
Ultimateone
most places can check boost and A/F readings while you dyno your car.
Old Jan 3, 2004 | 05:48 PM
  #51
ttsupra94's Avatar
ttsupra94
How about the cost of flashing?
Old Jan 3, 2004 | 07:17 PM
  #52
skrofa14's Avatar
skrofa14
http://www.technosquareinc.com/nissan.htm
Old Jan 4, 2004 | 04:45 AM
  #53
12SecZ's Avatar
12SecZ
I flashed at TS added the cats etcd several thousand miles ago and just pulled the plug. Porcelin is perfectly tan, engine is healthy, plugs are slightly rich like Jason's. I attribute this to my larger injectors and that I was FI on stock range plats. I now have copper 1 heat range cooler gapped at .37
Anyways, as promised here is my plug pulled yesterday. NOT lean.
Attached Thumbnails RT cat owners: are you running lean?-rtplug.jpg
Old Jan 4, 2004 | 06:37 AM
  #54
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Looks good to me!
Old Jan 4, 2004 | 06:50 AM
  #55
uro279's Avatar
uro279
12secZ,
what do you mean "larger injectors"? Did you buy news? So does this mean that to avoid becoming lean, we have to buy these too?
Also, what do you mean by "FI on stock range plats"?
Also, why did the Adm. remove the "quote" button?
thanx
Old Jan 4, 2004 | 08:51 AM
  #56
jreiter's Avatar
jreiter
It's just been renamed to the "reply" button. The small reply buttons inside each individual post will quote that post. The big reply button at the very bottom will do a generic non-quoted reply.
Old Jan 4, 2004 | 11:36 AM
  #57
12SecZ's Avatar
12SecZ
FI is Forced Induction Turbo, Super Charger and the Administratrion here has made a whole new section for it.
When you go FI or N20 (Nitrous) you usually need more fuel so I bought larger Injectors..
If you were just a stock car (N/A) then no, these injectors wouldn't help you like you think they would on your plugs with RT Cats. At least I don't think they would, I think you would need to piggy nack or reflash the amount of fuel going to the plugs. Plats is Platinum, I switched to Copper.
Old Jan 4, 2004 | 11:43 AM
  #58
Jason@Performance
Performance Nissan
Originally posted by alex30327
Jason,
Well, A Leak there would alow for more air to enter your engine then your throttle body is opening up to take in. So quite possibly yes.
It seems that for people who install the plenum NEED to get a TS update so the engine can be reconfigured to deal with the new air flow the plenum alows for.
Old Jan 4, 2004 | 11:56 AM
  #59
12SecZ's Avatar
12SecZ
yeah I have to reflash, plus when you remove the TB you have to reset the TB position and too. I am really wondering hard today about my reflash, just thoughts in my head I don't know the answer too yet.
Like my TB positioning was adjusted by TS via flash (A5T) I am wondering when I go into diagnostics mode and reset the TB position or heck even clear a code what effect that stuff I did in Diagnostic mode had on my TS TB flash etc? I know some of it is hard coded EPROM but I wonder if some of it is EEPROM?
Like I reset my ecu yesterday doing the 3, 5, 7, 10 dance, any effect on what TS did because of this Jason? I'm going back anyways just curiuos.
Old Jan 4, 2004 | 11:58 AM
  #60
12SecZ's Avatar
12SecZ
Or is it PROM and EPROM when flashing? Doesn't matter I guess my question is does changes in Diagnostic Mode effect the TS reflash?
