My SIKKY LS2 install thread
Old Aug 14, 2011 | 10:33 AM
  #161
Cass007's Avatar
Cass007
Originally Posted by bbs350z
+1 on info^ last i saw i think the starter ground itself on the ac compressor but not 100% sure. which post is the positive?
The top post is positive (one closest to the block), small post is for the purple wire to the harness connection and bottom large post is for the connection to the starter itself.
Confirmed by Franz that the bolts for the starter are the grounding mechanism for the unit and oly the AC condensor has the ground wire. Wiring sucks!!
What did everyone do for the power brake booster? I am considering just drilling yet another hole in the brake compartment and running a male to male barb fitting and hose from the Nissan brake unit to the main vacuum on the rear of the engine. I know this needs to be done, but it always seems that I procrastinate about these things when it comes to drilling holes and such.
BTW, I got the Defi oil temp sensor mounted where the stock LS sensor was. No apparent issues other than having to bu a set of uber large standard deep well sockets (it takes a 1-1/16" socket).
Old Aug 14, 2011 | 10:34 AM
  #162
Cass007's Avatar
Cass007
Originally Posted by jeffie7
You don't think he could get away with this if he was married? lol
So true... I have a special girl for sure
Old Aug 14, 2011 | 07:26 PM
  #163
jeffie7's Avatar
jeffie7
You'll have to bring her out to one of the jeff and linh parties.
Old Aug 14, 2011 | 10:11 PM
  #164
bbs350z's Avatar
bbs350z
cass where did you run all your aftermakret electronics to for power? also you got a location for switched power??
Old Aug 15, 2011 | 08:19 AM
  #165
Cass007's Avatar
Cass007
WTF are you doing up at 2am?
The gauges and such are pulled off the same wire that gives the radio power in the acc position. If you have an aftermarket head unit just go online and look at the wiring diagram to get the right wire and follow it back to the harness. Dimming for the gauges works in reverse, so you tap the parking light positive and when you turn the lights on, it dims the gauges. I have 5 Defis hooked up, so I had to increase the fuse to 20amp I believe.
The walbros are wired for power to the battery, but the pump switch is controlled by the factory Nissan unit, I had Frank Hill install the SP pump assembly so I can't say exactly how is wired. I do know that when I turn the key one position I can hear the pumps prime and build pressure. The fuse is in the box near the battery, top right fuse I believe (15amp), not sure if that helps at all.
I also have a few switched outputs on the ViPEC as well.
Old Aug 15, 2011 | 04:00 PM
  #166
delslow1975's Avatar
delslow1975
sub. looking good
Old Aug 15, 2011 | 04:46 PM
  #167
bbs350z's Avatar
bbs350z
Cass, can you send me a pic of your fuel pump?
Old Aug 15, 2011 | 07:21 PM
  #168
Cass007's Avatar
Cass007
Tomorrow or Wednesday. my brother-in-law that works for me is on vacation, so I actually have to work a few days this week. Do you just need the wiring at the top? That triple is a b1tch to install, so I'm not trying to pull it out or anything.
Old Aug 16, 2011 | 12:46 AM
  #169
bbs350z's Avatar
bbs350z
got the wiring hooked up to switched power (fyi its solid pink wire on ls harness-ornage is constant and black is ground)
just curious how you routed your hosing and how your wiring was done tis all.
Old Aug 17, 2011 | 02:21 PM
  #170
Cass007's Avatar
Cass007
Just a heads up... my boy Franz solved the tach issue
Using a sppedhut tach stepper motor integrated into our cluster setup and controlled by the stand alone. Factory appearing tach setup!!! The speedhut gauge will only allow travel to 7750rpms, so I will have to just spin the LS to less than that (I know I will, just having some fun). Custom harness is on its way in the next two weeks
Old Aug 17, 2011 | 03:31 PM
  #171
delslow1975
sweet
Old Aug 17, 2011 | 07:29 PM
  #172
Royal_T's Avatar
Royal_T
Yeah the speedhut was posted a long time ago to fix our tech problem.. Glad it worked out for you too..
Old Aug 17, 2011 | 08:21 PM
  #173
Fafonfoe's Avatar
Fafonfoe
Just run your 350Z Starter wire, Yellow and black to the Gm starter. I ran 3 Ground wires to the engine block so I didn't need to ground my starter. Also I did the exact same setup for my rad and fans to the T and ran into problems. I kept and still get my engine to around 230 and I'm using bigger fans now. Havent solved the issue but trying everything. If you do leave the 12" fans on there you will have to have a fan shroud. Don't forget to plumb the steam line. Good Luck.
Old Aug 17, 2011 | 09:07 PM
  #174
bbs350z's Avatar
bbs350z
cass would that speedhut tach stepper motor work with an ls ecu as opposed to a standalone?
Old Aug 18, 2011 | 02:26 AM
  #175
Cass007's Avatar
Cass007
You are misunderstanding me... he didn't fab the speedhut gauge into the factory cluster. He disassembled the speedhut gauge and swapped in the stepper motor that controls the needle onto the factory gauge. The instruments are 100% Nissan in appearance, but the tach will function.
He is working on my harness right now and is also putting together a solution for the AC switch so the factory push **** will still control the on/off function.
Old Aug 18, 2011 | 02:29 AM
  #176
bigcloud's Avatar
bigcloud
I'm digging the tach solution Cass!! Sounds pretty straight forward!!
Old Aug 18, 2011 | 02:32 AM
  #177
Cass007's Avatar
Cass007
Thanks for the info on the grounding and starter. Question on the steam line: where is it? How did you plumb it? Pics please.
Secondly, I had a friends Corvette over the weekend with the LS2 in it and it was showing normal operating temp to be in the 220*F range. Isn't that normal? Are we applying the VQ temp standard to the LS?
I will text him today and ask. I'm sorry I haven't gotten you the pic on the pumps yet. Birthdaypalooza starts mid morning today and will be three days of golf, drinks and sex. What a way to close out the summer
Old Aug 18, 2011 | 06:58 AM
  #178
binder's Avatar
binder
220 sounds a little high for normal idle but i could see that sitting in traffic or idling for long periods with a v8 could be around that temp.
Old Aug 21, 2011 | 04:51 AM
  #179
Cass007's Avatar
Cass007
Confirmed that my friends LS2 Vette has a normal running temp of 215-220*F.
Old Aug 21, 2011 | 04:58 AM
  #180
Cass007's Avatar
Cass007
Finished the negative side of the charging system the other day. Took the negative side of the LS sub harness and separated it from the starter wire and positive side. Then I cut the battery terminal head off, attached the other side to the AC compressor (stock location) with the wire oriented towards the front of the car. Ran the wire up along side the radiator, put a fresh connector on the end, then attached it to the stock Nissan ground point on the pass side frame rail.
