350z Oil pressure sending unit
Old Jan 25, 2016 | 11:36 AM
DeusExMaxima's Avatar
DeusExMaxima
I bought a sensor and installed it while doing an oil change. Problem solved. Thanks guys!!!
Old May 2, 2016 | 07:51 AM
willypowwow's Avatar
willypowwow
I had the same issue - the needle pegged all the way to the right when the engine started. Replaced the sensor and all is well. HOWEVER, while removing the original sensor I actually cracked the engine where the sensor is inserted, it's near a corner and a portion of the aluminum actually broke off. Luckily there was enough thread left that I was still able to screw the new part in, but be careful.
Old Aug 8, 2019 | 07:28 AM
Alex Tappin's Avatar
Alex Tappin
Default Solved for me...
I went ahead and finally bought a Nissan factory oil pressure unit... FIXED. I bought 3 from eBay and 1 from AutoZone all which read 20psi or so lower... So, buy nice or buy twice or 5 times like I did.
Old Nov 5, 2021 | 07:21 PM
Angry Ale's Avatar
Angry Ale
Hi Alex, I don't live in the US but facing the same issue, I have a friend living in Miami so he can receive the sensor, but, do you know how can I make a direct order to Nissan?
Buying it from where I live (with the authorized Nissan dealer) costs 220 USD and takes 2 months to arrive.. =S
Old Nov 5, 2021 | 08:57 PM
Alex Tappin
Not sure where you live but you can buy nissan plugs on eBay or Amazon just verify they are the Nissan ones.
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
Inspatatrac
Sep 8, 2015 02:12 PM
