TPS voltage low?
Old Jul 25, 2011 | 10:39 AM
John1006's Avatar
John1006
Default TPS voltage low?
I just got done wiring up my microedge controller for my nitrous. Well the microedge says that at idle voltage is 0.68 and its idling a little low. Under WOT it only says the voltage is ~4.15. I've searched and read that the WOT should be 5.1. Correct me if I'm wrong. Does this mean my tps is bad? Is it adjustable in anyway?
Old Jul 25, 2011 | 02:30 PM
DavesZ#3's Avatar
DavesZ#3
Adjustable - no. Recalibration - yes.
https://my350z.com/forum/6008226-post2.html
BTW - the throttle plate never opens up 100%
Old Jul 25, 2011 | 02:51 PM
John1006's Avatar
John1006
Forgot to mention. When I try to recalibrate it, after I hold down the pedal for 20 seconds and the SES light stops blinking, I let off the pedal and go to start the car and it almost immediately dies and won't idle.
Old Jul 25, 2011 | 04:41 PM
DavesZ#3's Avatar
DavesZ#3
Try disconnecting your controller to see if it is interfering with the TPS.
Old Jul 25, 2011 | 06:38 PM
John1006's Avatar
John1006
I disconnected it and still the same results. Dies immediately.
Old Jul 26, 2011 | 03:16 AM
DavesZ#3's Avatar
DavesZ#3
Hmmmmm... I'd be real surprised if this is a coincidence that the TPS failed now.
Can you get the engine to run but not idle?
As far as you can tell, no codes are being thrown , i.e. SES light on?
Old Jul 26, 2011 | 06:25 AM
John1006's Avatar
John1006
Well I downloaded te FSM. I found out that the voltage for pin 50 should be more than .35v fully released pedal. And it should be less than 4.75v fully depressed. So my tps seems to be within spec. Only SES light I have is p0037 and that's because of my test pipes. I have a JWT intake. What else could make it die when I start it? If I rev it up, it'll come back down and idle, but idles at about 450~500, and almost feels like it's going to stall. Otherwise performance though is fine.
Old Jul 26, 2011 | 08:47 AM
str8dum1's Avatar
str8dum1
did you have your car hot when you did the TPS reset. everything must be at operating temps for the tps to calibrate
Old Jul 26, 2011 | 09:14 AM
John1006's Avatar
John1006
Yes sir. Did everything according to the FSM. Would a vacuum leak make me have low idle? I've only experienced vacuum leaks raising your idle.
350Z_Al
Oct 29, 2020 07:44 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
