Is it normal?
Old Aug 1, 2011 | 06:25 PM
mitsumissile's Avatar
mitsumissile
Default Is it normal?
I have installed the SPEC clutch and flywheel. Can you guys take a look the video? http://s248.photobucket.com/albums/g...t=L1160123.mp4
The first half shows, when you press the clutch peddle you can't get into the 1st gear instantly and it also make some noise. We measure the time when you press the clutch, You have to wait 5-7 seconds before you can put it in 1st gear. Is it normal?
The customer can't accept that, he said before he use the stock one, he can drive normally. Now it's embarrass when he come to a stop sign.
Old Aug 1, 2011 | 06:31 PM
resident25's Avatar
resident25
Definitly not supposed to be normal.
Old Aug 1, 2011 | 07:18 PM
jerseystyle's Avatar
jerseystyle
Try using the search function and this belongs in the tech section.
drivessidewayz's Avatar
drivessidewayz
Are you absolutely sure everything is assembled correctly? I've never heard a noise like that >.< Unless it's grinding and it just sounds like a squeal through the video.
Old Aug 1, 2011 | 07:35 PM
mitsumissile
I have email the SPEC. They said it's normal. Here is the reply
"That is a dual mass application, so it is normal for there to be transmission noises with a billet flywheel. You must be hearing the transmission rotating to a stop (so you can get it into gear). Does it seem like it is taking longer for the transmission to stop turning ?"
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sales@czp
Sep 23, 2019 03:30 PM
codek
Sep 28, 2015 03:03 AM
