Do concentric slave cylinders have a spring inside?
Old Aug 1, 2011 | 10:02 PM
winchman's Avatar
winchman
Default Do concentric slave cylinders have a spring inside?
I know lots of people have taken them out, but has anyone taken one apart? I've recently saw one off another vehicle, and it has a rather hefty spring that pushes the throwout bearing against the clutch diaphragm spring. All the photos I could find show a rubber boot on the 350Z CSC.
So, is there a spring inside the 350Z CSC similar to the one shown in the attached photo?
Attached Thumbnails Do concentric slave cylinders have a spring inside?-miscellaneous-cannon-111.jpg
Old Aug 2, 2011 | 10:55 PM
winchman's Avatar
winchman
Wow, 290 views and no one has seen the inside of a CSC?
Old Aug 3, 2011 | 03:31 PM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
Most of them have springs, Certain aftermarket internal slaves like Tilton, AP racing ect do not as they are shimmed during installation to have the correct clearance. These are mostly used on race on cars as they have to be adjusted with shims as the clutch wears.
Old Aug 3, 2011 | 08:53 PM
winchman's Avatar
winchman
Thanks for the info.
So, seeing as how the spring is compressed when the clutch is engaged (pedal up), the throwout bearing must be pushing against the diaphragm spring in the pressure plate all the time. I wonder how they get the "free play" at the top of the pedal travel when there's no free play where it really counts.
Only a bean counter or a weight reduction specialist or someone on Nissan's drive train B-team, would think the CSC is a good idea.
Old Aug 4, 2011 | 03:24 AM
ZSpeedPerformance
Free play is only there for the master cyl, Once the cars warm up everything expands, This includes the rod in the master cyl. If you do not retain a bit of free play in the master cylinder adjustment you will begin to block the orifice inside the master that allows the fluid to return into the reservoir when you let the pedal up.
If mis adjusted this can cause pressure to build in the system and it can start pushing on the clutch itself and cause the clutch to slip.
In any car the TOB constantly rides on the pressure plate fingers.
07ZEKE
Aug 23, 2021 09:15 PM
sherm
Apr 11, 2020 05:21 PM
3vilbunny
Jul 18, 2017 05:10 PM
