My short-winded treatise on Internet Einsteins
Originally posted by Chebosto
the ECU is the only way you can actively retard timing throughout the rpm band when necessary- and have the fuel/air to go with it.
If the MAF is not maxed out as far as the signal input to the ecu goes, then I would have to say that the ecu reprogramming is an excellent way to control fuel and spark when boosting. Which still leaves me with one big problem, that being the one-size-fits-all nature of it. Other than those that are close enough to get them to do custom tuning on their car, TS would have to be extremely conservative or you are still taking some risk.
Either way, I'm still planning to do my own testing of the MAF output to see what it's doing. And there are still some advantages to using a J&S whether you have an ecu reflash or not.
On edit:
I forgot to ask you Cheston. You say they are pulling timing at 6k rpm and up. Is this the only place? Obviously it needs to be pulled up there, but I would think they'd do more with the timing than that...
Specifics, obviously i cannot say, it is changed throughout the entire map. i 'generally' it is where 6k+ until redline is where it is most important--
Cheston......you guys have done a great job on all of your research......i'll be coming to see you when i can get away for a weekend.......i'm getting really tired of driving my supercharged car around at 4Krpms
I ended up in a commute job going from Sacramento to Oakland CA ( 4 hrs a day driving) throughout all of 2004 and never once ever had any problems with my FI AT Z tuned by TS.
EJ ended up seeing me hit WOT at 10 lbs of Boost on stock internals and I even had video up on the net for a long time of these runs. No more sticking at WOT with the AT either.
Bottom line was the larger fuel pump, the larger P.E. Injectors and the TS ECU ran my FI car at 10 lbs for 30 thousand more miles before I traded it in. The plenum I had may have played a role (more air), I may never know but a reflash was necassary after adding the aftermarket Crawford Plenum and after that I was DIALED and stayed dialed.
So I thought I would let everyone know that after all was said and done, my setup worked, and worked well in all temperatures. Man I miss that car!!!
Peace Out,
P.S.
EJ If you are still around hit me up man it's been awhile!
Peace Out,
P.S.
Workshop12
Mar 23, 2020 01:45 PM
